Hello! I have a pretty nice almost rustfree Citroen jumpy from 1998 it has the 1.9 td with a Bosch mechanic fuel pump.
The bad thing is that is leaking, so i have to order and replace sealings.
To order the right sealings i have to know which pump it is.
Anyway the number plate on the front of the pump are impossible to read...
I hope there is someone that know what identification number or what my Bosch pump is called?
Thank you
Hello! Citroen jumpy 1998 1.9 td. What is my Bosch fuel pump called
Jumpyer 98
- x 8296
Re: Hello! Citroen jumpy 1998 1.9 td. What is my Bosch fuel pump called
It's almost certainly a Bosch VP20 or AS3. Both look (and are) very similar, the AS3 differing in having electronically controlled timing.
Pop up a photo of the pump and I can confirm. In any case, seal kits are the same for the VP20 and AS3.
A little on how to do the job can be found here:
https://www.eastment.net/boschpump1.htm
The biggest PITA by far is de-armouring the pump!
