308 II 1.6THP Oil change 156HP
ivica001
Unread post by ivica001 »
I have Peugeot 308 II 1.6 THP 156HP 2014.
Manufacture recommendation is TotalEnergies QUARTZ INEO, i found there is two types to buy RCP and HTC, does anyone can tell me which one should i use from this two ?
PaulC5
x 682
Re: 308 II 1.6THP Oil change 156HP
Unread post by PaulC5 »
If you post your vin it will be possible for admin to look up your car.
Arkis
x 27
Unread post by Arkis »
Look at the norms. For your engine the oil must have norm PSA B71 2290. So it's the HTC version (High Temperature Control). RCP stands for Renault Common Parts and it has norms for Renault engines.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
ivica001
ivica001
Arkis wrote: 17 Mar 2025, 12:12 Look at the norms. For your engine the oil must have norm PSA B71 2290. So it's the HTC version (High Temperature Control). RCP stands for Renault Common Parts and it has norms for Renault engines.
Mihael_M
x 37
Unread post by Mihael_M »
viewtopic.php?p=768074#p768074
Since your engine is EP6CDT (you didn't mention it, so I assume), and according to the table from Stelantis, you should use 0W30 B712312, which is:
https://www.autodoc.co.uk/total/15229578#engine-oil
Although if it were my car I would pour 5W30 B712290.
https://lubricants.catalog.totalenergie ... -ecs-5w-30
