Hello,
Would it be possible to get the specs for a couple of C5 Xs?
I'm only really interested in confirming which (if any) factory options were fitted to these vehicles if that's easier.
The two VINs are:
VR7**************[VIN obfuscated, can be read by forum staff]
Many thanks in advance.
Citroen C5 X Build Sheet from VIN
- x 6955
Re: Citroen C5 X Build Sheet from VIN
Ok, so be aware that this will not necessarily provide you with a feature list of any options packs for example.
Some features are part of an option pack that is extra when ordering the car over and above the trim level specification.
VIN Ending 204 - C5 X (E43 EIC) CROSSOVER 1.6 PureTech 16v 225 (EP6FADTXHP Euro 6.3) 4X2 8-SPEED AUTOMATIC HYBRID
VIN Ending 028 - C5 X (E43 EIC) CROSSOVER 1.6 PureTech 16v 225 (EP6FADTXHP Euro 6.3) 4X2 8-SPEED AUTOMATIC HYBRID
| Vehicle Characteristics | |
| Vehicle family | C5 X (E43 EIC) |
| AS/RP N° | 16555 VD 1 0233 |
| Warranty Start Date | 20/07/2022 |
| Engine serial number | 10 FKBJ 2875134 |
| BER | e9*2018/858*11066*01 |
| P4A | 9839622299 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C5 X (E43 EIC) |
| SILHOUETTE | CROSSOVER |
| TRIM LEVEL | UPPER MEDIUM |
| ENGINE | EP6FADTXHP 1.6L PETROL |
| TRANSMISSION | 4X2 8-SPEED AUTOMATIC HYBRID |
| PAINT TYPE | PEARLESCENT METALLIC EXTERIOR THREE-LAYER TRIM TYPE |
| BODY COLOUR | PEARLESCENT WHITE PAINT |
| INTERIOR TRIM TYPE | PALOMA "LR" LEATHER |
| UPHOLSTERY COLOUR | "FD" |
| GEARBOX (CHARACTERISTICS) | EATNG8 |
| CONVERSION GUIDANCE | WITHOUT CONVERSION |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| ENGINE (TYPE) | EP TYPE ENGINE |
| ROOF (EXT. ASPECT) | BLACK PEARL ROOF |
| Fuel Supply-Engine | |
| FUEL | UNLEADED PETROL 95 QUALITY A/B/E/E+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
| CAPACITY | 1600 CM3 |
| FUEL TANK INSULATION | WITHOUT FUEL TANK INSULATION |
| COOLING MOTOR | RADIATOR EP28 28DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | WITH "OBD" AUTO-DIAGNOSTICS |
| DEVICE (ANTIPOLLUTION) | WITHOUT ANTI-POLLUTION DEVICE |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
| FAN | VARIABLE SPEED FAN 200W AERO DYNAMIC FLAP |
| INJECTION ASSOCIATED VARIANT | MOUNTING BOSCH |
| DRIVE TRAIN | PHEV DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | FINAL DRIVE RATIO 15 X 58 |
| WHEEL STYLE | 19-INCH STYLE WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 19 INCH TYRE FIT |
| TYRE (SIZE, TYPE) | 205/55 R19 97V TYRE |
| DRIVING WHEELS | 2 DRIVEN WHEELS |
| WHEELS FITTED | WHEELS FITTED 7 J19 RIM OFFSET 41 |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| GEARBOX TYPE | GEARBOX TYPE EATN8 |
| Suspension-Steering-Brakes | |
| BRAKING ASSISTANCE IN REVERSE GEAR | COLLISION WARNING - RCTA |
| REAR ANTI-ROLL BAR | REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| SUSPENSION | NORMAL SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| STEERING (OPERATION) | HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING |
| PEDAL BRACKET (TYPE) | PEDAL ALUMINIUM |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| SIDE MOULDINGS (DIMENSION) | WIDE SIDE PROTECTORS + SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | BLACK CENTRE CAPS+BLACK BOLTS DESIGN |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY |
| EXHAUST TAILPIPE TRIM | CHROME EXHAUST OUTLET TRIM |
| ENGINE BAY SOUNDPROOFING | BULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH |
| WINDSCREEN GLASS (TYPE) | STANDARD WINDSCREEN GLASS |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| BUMPER | CHROME + BODY COLOUR FRONT/REAR BUMPER |
| LUGGAGE RACK | WITHOUT ROOF BARS |
| FRONT FOGLAMP | LED FOG LAMPS + CORNERING LAMP |
| PANORAMIC VISUAL AID | DIGITAL PANORAMIC VISUAL ASSISTANCE |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| SUN ROOF | SUNROOF SEQUENTIAL ASSISTED CONTROL + ANTI PINCH |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED RR WINDOW GLASS |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS+BOOT+CONTACTLESS STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | VOLUME + PERIMETER + LIFT |
| FRONT HEAD RESTRAINT | 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT |
| REAR SEAT | MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK |
| BLIND SPOT DETECTION | BLIND SPOT MONITORING + LANE CHANGE ASSIST |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| INTERIOR ALARM | 3-SENSOR INTERIOR ALARM |
| RADIO TELEPHONE | 2 SMARTPHONES |
| LUGGAGE COVER | SCREEN |
| REAR SEATBELT | 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING |
| FRONT SEATBELT | REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX+ADDITIONAL OUTLET |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GRAB HANDLES | FRONT + REAR + RETRACTABLE HANDLES |
| CONSOLE | LONG CONSOLE + REAR AIR DUCT |
| DRIVING POSITION | RIGHT HAND DRIVE |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | LED GLOVE BOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL |
| DASHBOARD EQUIPMENT | BLACK STRIP+WOOD FILM DECOR |
| INSTRUMENT PANEL (CHARACTERISTICS) | INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX |
| LOUDSPEAKER | 5 FR SPEAKERS (2 TW + 2 FR + 1 CENT) |
| ADDITIONAL BLOWER | WITHOUT ADDITIONAL PULSE |
| POLLEN FILTER | WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS |
| LANE KEEPING MANAGEMENT ASSISTANCE | TRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT |
| FRONT PASSENGER SEAT CONTROL | ELECTRIC FRONT PASSENGER SEAT CONTROL |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT |
| STOWAGE BIN | STORAGE BOX WITHOUT COOLING |
| SATELLITE NAVIGATION SYSTEM | CONNECTABLE NAVIGATION SYSTEM |
| HEADLAMP BULBS | ECO LED |
| TRAFFIC INFORMATION READER | LKA STRUCTURAL EDGE |
| DISPLAY | 12-INCH COLOUR HD TOUCHSCREEN DISPLAY |
| COURTESY MIRROR | DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING |
| FOOTREST | WITHOUT FOOTREST |
| CUSHION PADDING | PADDING WITH PASSENGER DETECTION PAD |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1 |
| FRONT LATERAL AIRBAG | FR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN |
| FOOTWELL LIGHTING | FOOTWELL LIGHTING WITH LED |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITHOUT WIFI |
| STORAGE (DRIVING POSITION) | STORAGE COMPARTMENT BRAKED OPENING |
| RADIO RECEIVER | ANALOGUE + DAB RADIO RECEIVER |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | ACC3 DECEL0 + ACCEL0 |
| DRIVER’S SEAT HEIGHT CONTROL | ELECTRIC CONTRL DRIVERS HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR |
| AIR CON./TEMPERATURE REGULATION | AUTOMATIC AIR CONDITIONNED BI-ZONE |
| STORAGE (OTHERS) | PLAIN STORAGE POCKET |
| LOAD SPACE STORAGE | BOOT LATERAL STRAP + NET |
| REAR SEAT PADDING | WITHOUT RR PASSENGER DETECTION |
| TUNER RADIO | DUAL RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY |
| FLOOR MAT | FR + RR MATS |
| RADIO FREQUENCY | RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1 |
| LOCKING CONTROL | CENTRAL DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | FULL FLOWER LEATHER ST WHEEL |
| SEATING ASSOCIATED VARIANT | LOWER SEAT ASSOCIATED VARIANT |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| AUDIO PACK AUXILIARY SOCKET | AUXILIARY SOCKET AUDIO PACK 2 USB TYPE C |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ISTT60 |
| BATTERY | L2 680 60AH EFR 680 BATTERY BECOMES EF |
| STARTER MOTOR | WITHOUT STARTER MOTOR |
| CEN. LOCKING REM CONTROL FREQUENCY | LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
| ELECTRICAL EQUIPMENT (SUPPLY) | CAMEL BATTERY |
| BATTERY CHARGER | SINGLE-PHASE 7 KW ON-BOARD CHARGER |
| MULTIPLEXING | NEA R1 |
| ELECTRIC VEHICLE CHARGING PLUG | WITHOUT VEHICLE LOAD RECOGNITION |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| MODIF. DURING MODEL YEAR | WITHOUT MINOR MODIFICATIONS |
| CONDENSER (SPECIFICATIONS) | CONDENSER 23,5DM2 THICKNESS 16 |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
| RADIO HEADPHONE SOCKET | DOUBLE ACCESSORY SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | UPPER REINFORCED SIDE IMPACT PROTECTORS |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| AS/RP N° | 16555 VD 1 0081 |
| Warranty Start Date | 30/06/2022 |
| Engine serial number | 10 FKBJ 2874803 |
| P4A | 9839622299 |
| PAINT TYPE | PAINTED METALLIC EXT TRIM TYPE |
| BODY COLOUR | ARTENSE GREY PAINT |
| Body Fittings | |
| Electrical | |
| Miscellaneous | |
funboyt
That's magic. Thanks a lot!
funboyt
Would it be possible to get the specs for one more? I've made another donation to the fund for your trouble.
The VIN is VR7**************[VIN obfuscated, can be read by forum staff].
Thank you.
Thank you.
- x 1056
Here you go.
Vehicle characteristics
Vehicle family C5 X (E43 EIC)
AS/RP N° 16771 VD 1 0089
Warranty Start Date 28/02/2023
Engine serial number 10 FKBJ 2953013
OPB 00QL
BER e9*2018/858*11066*04
P4A 9839622299
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 X (E43 EIC)
SILHOUETTE CROSSOVER
TRIM LEVEL UPPER MEDIUM
ENGINE EP6FADTXHP 1.6L PETROL
TRANSMISSION 4X2 8-SPEED AUTOMATIC HYBRID
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR SMART GREY PAINT
INTERIOR TRIM TYPE PALOMA "LR" LEATHER
UPHOLSTERY COLOUR "FD"
GEARBOX (CHARACTERISTICS) EATNG8
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EP TYPE ENGINE
ROOF (EXT. ASPECT) BODY COLOUR ROOF
Fuel supply-Engine
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY 1600 CM3
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
FAN VARIABLE SPEED FAN 200W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN PHEV DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
FINAL DRIVE RATIO FINAL DRIVE RATIO 15 X 58
WHEEL STYLE 19-INCH STYLE WHEEL
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 205/55 R19 97V TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED WHEELS FITTED 7 J19 RIM OFFSET 41
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPE GEARBOX TYPE EATN8
BRAKING ASSISTANCE IN REVERSE GEAR COLLISION WARNING - RCTA
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
Body fittings
TOWBAR WITHOUT TOWBAR
SIDE MOULDINGS (DIMENSION) WIDE SIDE PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE) BLACK CENTRE CAPS+BLACK BOLTS DESIGN
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIM CHROME EXHAUST OUTLET TRIM
ENGINE BAY SOUNDPROOFING BULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER CHROME + BODY COLOUR FRONT/REAR BUMPER
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID DIGITAL PANORAMIC VISUAL ASSISTANCE
SPARE WHEEL WITHOUT SPARE WHEEL
SUN ROOF WITHOUT SUN ROOF
GLASS (APPEARANCE) TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTING FRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior fittings
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
BLIND SPOT DETECTION BLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMREST WITH REAR SEAT ARMREST
INTERIOR ALARM 3-SENSOR INTERIOR ALARM
RADIO TELEPHONE 2 SMARTPHONES
LUGGAGE COVER SCREEN
REAR SEATBELT 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELT REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONING WITH HEATER MATRIX+ADDITIONAL OUTLET
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN MPH
GRAB HANDLES FRONT + REAR + RETRACTABLE HANDLES
CONSOLE LONG CONSOLE + REAR AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED GLOVE BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENT BLACK STRIP+WOOD FILM DECOR
INSTRUMENT PANEL (CHARACTERISTICS) INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX
LOUDSPEAKER 5 FR SPEAKERS (2 TW + 2 FR + 1 CENT)
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCE TRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING
FRONT PASSENGER SEAT HEIGHT CONTROL FR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL ELECTRIC FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
STOWAGE BIN STORAGE BOX WITHOUT COOLING
SATELLITE NAVIGATION SYSTEM CONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBS ECO LED
TRAFFIC INFORMATION READER LKA STRUCTURAL EDGE
DISPLAY 12-INCH COLOUR HD TOUCHSCREEN DISPLAY
COURTESY MIRROR DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTREST WITHOUT FOOTREST
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
FOOTWELL LIGHTING FOOTWELL LIGHTING WITH LED
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
WIFI WITHOUT WIFI
STORAGE (DRIVING POSITION) STORAGE COMPARTMENT BRAKED OPENING
RADIO RECEIVER ANALOGUE + DAB RADIO RECEIVER
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL ACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
STORAGE (OTHERS) PLAIN STORAGE POCKET
LOAD SPACE STORAGE BOOT LATERAL STRAP + NET
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
FLOOR MAT FR + RR MATS
RADIO FREQUENCY RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL FULL FLOWER LEATHER ST WHEEL
SEATING ASSOCIATED VARIANT LOWER SEAT ASSOCIATED VARIANT
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKET AUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATOR ISTT60
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR WITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) LEOCH BATTERY
BATTERY CHARGER SINGLE-PHASE 7 KW ON-BOARD CHARGER
MULTIPLEXING NEA R1
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS) CONDENSER 23,5DM2 THICKNESS 16
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPES STANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS UPPER REINFORCED SIDE IMPACT PROTECTORS
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
OPB 00QL
P4A 9839622299
General information
Fuel supply-Engine
CAPACITY 1600 CM3
Body fittings
Interior fittings
WIFI WITHOUT WIFI
Electrical
ALTERNATOR ISTT60
MULTIPLEXING NEA R1
Miscellaneous
