Citroen C5 X Build Sheet from VIN
funboyt
Unread post by funboyt »
Hello,
Would it be possible to get the specs for a couple of C5 Xs?
I'm only really interested in confirming which (if any) factory options were fitted to these vehicles if that's easier.
The two VINs are:
VR7**************[VIN obfuscated, can be read by forum staff]
Many thanks in advance.
x 6957
Re: Citroen C5 X Build Sheet from VIN
Ok, so be aware that this will not necessarily provide you with a feature list of any options packs for example.
Some features are part of an option pack that is extra when ordering the car over and above the trim level specification.
VIN Ending 204 - C5 X (E43 EIC) CROSSOVER 1.6 PureTech 16v 225 (EP6FADTXHP Euro 6.3) 4X2 8-SPEED AUTOMATIC HYBRID
Vehicle Characteristics
Vehicle familyC5 X (E43 EIC)
AS/RP N°16555 VD 1 0233
Warranty Start Date20/07/2022
Engine serial number10 FKBJ 2875134
BERe9*2018/858*11066*01
P4A9839622299
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC5 X (E43 EIC)
SILHOUETTECROSSOVER
TRIM LEVELUPPER MEDIUM
ENGINEEP6FADTXHP 1.6L PETROL
TRANSMISSION4X2 8-SPEED AUTOMATIC HYBRID
PAINT TYPEPEARLESCENT METALLIC EXTERIOR THREE-LAYER TRIM TYPE
BODY COLOURPEARLESCENT WHITE PAINT
INTERIOR TRIM TYPEPALOMA "LR" LEATHER
UPHOLSTERY COLOUR"FD"
GEARBOX (CHARACTERISTICS)EATNG8
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EP TYPE ENGINE
ROOF (EXT. ASPECT)BLACK PEARL ROOF
Fuel Supply-Engine
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
FUEL TANK INSULATIONWITHOUT FUEL TANK INSULATION
COOLING MOTORRADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION)WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
FANVARIABLE SPEED FAN 200W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
DRIVE TRAINPHEV DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLE19-INCH STYLE WHEEL
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE19 INCH TYRE FIT
TYRE (SIZE, TYPE)205/55 R19 97V TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEELS FITTEDWHEELS FITTED 7 J19 RIM OFFSET 41
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPEGEARBOX TYPE EATN8
Suspension-Steering-Brakes
BRAKING ASSISTANCE IN REVERSE GEARCOLLISION WARNING - RCTA
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body Fittings
TOWBARWITHOUT TOWBAR
SIDE MOULDINGS (DIMENSION)WIDE SIDE PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE)BLACK CENTRE CAPS+BLACK BOLTS DESIGN
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIMCHROME EXHAUST OUTLET TRIM
ENGINE BAY SOUNDPROOFINGBULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERCHROME + BODY COLOUR FRONT/REAR BUMPER
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPLED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AIDDIGITAL PANORAMIC VISUAL ASSISTANCE
SPARE WHEELWITHOUT SPARE WHEEL
SUN ROOFSUNROOF SEQUENTIAL ASSISTED CONTROL + ANTI PINCH
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINT4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEATMONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
BLIND SPOT DETECTIONBLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
INTERIOR ALARM3-SENSOR INTERIOR ALARM
RADIO TELEPHONE2 SMARTPHONES
LUGGAGE COVERSCREEN
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTREEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX+ADDITIONAL OUTLET
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GRAB HANDLESFRONT + REAR + RETRACTABLE HANDLES
CONSOLELONG CONSOLE + REAR AIR DUCT
DRIVING POSITIONRIGHT HAND DRIVE
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGLED GLOVE BOX LIGHTING
BOOT AND LOAD SPACE LIGHTINGBOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENTBLACK STRIP+WOOD FILM DECOR
INSTRUMENT PANEL (CHARACTERISTICS)INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX
LOUDSPEAKER5 FR SPEAKERS (2 TW + 2 FR + 1 CENT)
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
POLLEN FILTERWITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCETRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING
FRONT PASSENGER SEAT HEIGHT CONTROLFR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLELECTRIC FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
STOWAGE BINSTORAGE BOX WITHOUT COOLING
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSECO LED
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAY12-INCH COLOUR HD TOUCHSCREEN DISPLAY
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTRESTWITHOUT FOOTREST
CUSHION PADDINGPADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTDRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
FOOTWELL LIGHTINGFOOTWELL LIGHTING WITH LED
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
WIFIWITHOUT WIFI
STORAGE (DRIVING POSITION)STORAGE COMPARTMENT BRAKED OPENING
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED BI-ZONE
STORAGE (OTHERS)PLAIN STORAGE POCKET
LOAD SPACE STORAGEBOOT LATERAL STRAP + NET
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
FLOOR MATFR + RR MATS
RADIO FREQUENCYRADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELFULL FLOWER LEATHER ST WHEEL
SEATING ASSOCIATED VARIANTLOWER SEAT ASSOCIATED VARIANT
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKETAUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORISTT60
BATTERYL2 680 60AH EFR 680 BATTERY BECOMES EF
STARTER MOTORWITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY)CAMEL BATTERY
BATTERY CHARGERSINGLE-PHASE 7 KW ON-BOARD CHARGER
MULTIPLEXINGNEA R1
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS)CONDENSER 23,5DM2 THICKNESS 16
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSUPPER REINFORCED SIDE IMPACT PROTECTORS
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
VIN Ending 028 - C5 X (E43 EIC) CROSSOVER 1.6 PureTech 16v 225 (EP6FADTXHP Euro 6.3) 4X2 8-SPEED AUTOMATIC HYBRID
AS/RP N°16555 VD 1 0081
Warranty Start Date30/06/2022
Engine serial number10 FKBJ 2874803
P4A9839622299
General Information
SILHOUETTECROSSOVER
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOURARTENSE GREY PAINT
Fuel Supply-Engine
CAPACITY1600 CM3
Body Fittings
Interior Fittings
LUGGAGE COVERSCREEN
WIFIWITHOUT WIFI
Electrical
ALTERNATORISTT60
MULTIPLEXINGNEA R1
Miscellaneous
funboyt
That's magic. Thanks a lot!
funboyt
Would it be possible to get the specs for one more? I've made another donation to the fund for your trouble.
The VIN is VR7**************[VIN obfuscated, can be read by forum staff].
Thank you.
x 1056
Unread post by wheeler »
Here you go.
Vehicle characteristics
Vehicle family C5 X (E43 EIC)
AS/RP N° 16771 VD 1 0089
Warranty Start Date 28/02/2023
Engine serial number 10 FKBJ 2953013
OPB 00QL
BER e9*2018/858*11066*04
P4A 9839622299
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 X (E43 EIC)
SILHOUETTE CROSSOVER
TRIM LEVEL UPPER MEDIUM
ENGINE EP6FADTXHP 1.6L PETROL
TRANSMISSION 4X2 8-SPEED AUTOMATIC HYBRID
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR SMART GREY PAINT
INTERIOR TRIM TYPE PALOMA "LR" LEATHER
UPHOLSTERY COLOUR "FD"
GEARBOX (CHARACTERISTICS) EATNG8
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EP TYPE ENGINE
ROOF (EXT. ASPECT) BODY COLOUR ROOF
Fuel supply-Engine
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY 1600 CM3
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
FAN VARIABLE SPEED FAN 200W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN PHEV DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
FINAL DRIVE RATIO FINAL DRIVE RATIO 15 X 58
WHEEL STYLE 19-INCH STYLE WHEEL
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 205/55 R19 97V TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED WHEELS FITTED 7 J19 RIM OFFSET 41
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPE GEARBOX TYPE EATN8
BRAKING ASSISTANCE IN REVERSE GEAR COLLISION WARNING - RCTA
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
Body fittings
TOWBAR WITHOUT TOWBAR
SIDE MOULDINGS (DIMENSION) WIDE SIDE PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE) BLACK CENTRE CAPS+BLACK BOLTS DESIGN
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIM CHROME EXHAUST OUTLET TRIM
ENGINE BAY SOUNDPROOFING BULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER CHROME + BODY COLOUR FRONT/REAR BUMPER
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID DIGITAL PANORAMIC VISUAL ASSISTANCE
SPARE WHEEL WITHOUT SPARE WHEEL
SUN ROOF WITHOUT SUN ROOF
GLASS (APPEARANCE) TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTING FRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior fittings
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
BLIND SPOT DETECTION BLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMREST WITH REAR SEAT ARMREST
INTERIOR ALARM 3-SENSOR INTERIOR ALARM
RADIO TELEPHONE 2 SMARTPHONES
LUGGAGE COVER SCREEN
REAR SEATBELT 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELT REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONING WITH HEATER MATRIX+ADDITIONAL OUTLET
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN MPH
GRAB HANDLES FRONT + REAR + RETRACTABLE HANDLES
CONSOLE LONG CONSOLE + REAR AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED GLOVE BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENT BLACK STRIP+WOOD FILM DECOR
INSTRUMENT PANEL (CHARACTERISTICS) INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX
LOUDSPEAKER 5 FR SPEAKERS (2 TW + 2 FR + 1 CENT)
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCE TRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING
FRONT PASSENGER SEAT HEIGHT CONTROL FR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL ELECTRIC FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
STOWAGE BIN STORAGE BOX WITHOUT COOLING
SATELLITE NAVIGATION SYSTEM CONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBS ECO LED
TRAFFIC INFORMATION READER LKA STRUCTURAL EDGE
DISPLAY 12-INCH COLOUR HD TOUCHSCREEN DISPLAY
COURTESY MIRROR DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTREST WITHOUT FOOTREST
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT DRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
FOOTWELL LIGHTING FOOTWELL LIGHTING WITH LED
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
WIFI WITHOUT WIFI
STORAGE (DRIVING POSITION) STORAGE COMPARTMENT BRAKED OPENING
RADIO RECEIVER ANALOGUE + DAB RADIO RECEIVER
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL ACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
STORAGE (OTHERS) PLAIN STORAGE POCKET
LOAD SPACE STORAGE BOOT LATERAL STRAP + NET
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
FLOOR MAT FR + RR MATS
RADIO FREQUENCY RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL FULL FLOWER LEATHER ST WHEEL
SEATING ASSOCIATED VARIANT LOWER SEAT ASSOCIATED VARIANT
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKET AUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATOR ISTT60
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR WITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) LEOCH BATTERY
BATTERY CHARGER SINGLE-PHASE 7 KW ON-BOARD CHARGER
MULTIPLEXING NEA R1
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS) CONDENSER 23,5DM2 THICKNESS 16
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPES STANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS UPPER REINFORCED SIDE IMPACT PROTECTORS
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
