C5x7 3rd time steering leaking
aerodynamica
x 215
Unread post by aerodynamica »
It has happened a 3rd time. Lasted 2 years but it's leaking again. Copper grease on the shaft didn't save it.
Don't know what to do now, can steering racks still be got?
MOT in a month 😐
Graeme M
x 6947
Re: C5x7 3rd time steering leaking
Probably was too late if the rust was internal and spread up. My second replacement with CV boot protection and marine grease lasted whilst in my ownership and then I sold mine on.
You have a 180° Angled Steering rack for reference Graeme and these are the current part numbers:
Brand New Rack, part: 9801415480, £2,035.74
Standard Exchange Rack, part: 1663665380, £1201.36
aerodynamica
x 215
Thanks Marc, brilliant help as usual
Graeme M
x 1056
Unread post by wheeler »
I had been finding a lot of places that do reconditioned racks stopped touching them as they didn't want the hassle.
aerodynamica
x 215
wheeler wrote: 02 Mar 2025, 11:34 I had been finding a lot of places that do reconditioned racks stopped touching them as they didn't want the hassle.
To be honest, the first track I got wasn't very well reconditioned, paint flaking off it and visible cutting disk damage where they'd removed the pinion valve housing bolts. It's so much hassle to change the thing or that I just don't trust them.
Graeme M
x 1056
My first rack lasted about 2 years, when i went back to the same company again for another one they said they dont do them anymore as too much grief.
Tried a few places & got a similar response.
wurlycorner
x 271
Unread post by wurlycorner »
In terms of parts supply, believe it or not... GSFCarParts list reconditioned racks for X7's!
Iain
CX DTR T2 Safari (silver)
x 2366
Unread post by MattBLancs »
wurlycorner wrote: 02 Mar 2025, 18:06 In terms of parts supply, believe it or not... GSFCarParts list reconditioned racks for X7's!
Interesting!
https://www.gsfcarparts.com/parts/steer ... ering-rack
£601.99 -current 20% discount code (brings down to £481.59)
And reckons £207 back for the old rack.
Seems cheap!?
wurlycorner
x 271
Yep! Worth a shot I reckon.
I stuck an Elstock alternator on my other C5 a year ago and it's been absolutely fine - so there's nothing ringing alarm bells about them for me.
Iain
aerodynamica
x 215
Good find! That's surprising and not as excessive cost compared to the ones previously mentioned
Graeme M
x 1473
Unread post by xantia_v6 »
I am surprised that no-one has yet tried a speedi-sleeve on one of these.
aerodynamica
x 215
xantia_v6 wrote: 03 Mar 2025, 07:12 I am surprised that no-one has yet tried a speedi-sleeve on one of these.
You know, I was thinking about that yesterday. I'd be keen but it's not something I've done before. Do you have to match it up with a shaft seal with a different (,larger) inner diameter?
Graeme M
x 1473
No, the sleeve is thin enough that it should be inside the tolerance range of a conventional seal (probably not true for teflon seals).
I used one on a Jaguar steering rack pinion and it worked well.
aerodynamica
x 215
xantia_v6 wrote: 03 Mar 2025, 08:05 No, the sleeve is thin enough that it should be inside the tolerance range of a conventional seal (probably not true for teflon seals).
I'd like to do this. Might look into it again. It is possibly the only true long term fix for this issue.
Graeme M
x 2366
aerodynamica wrote: 03 Mar 2025, 08:34
I bought a pair of speedy sleeves "just in case" based on info on here (so I'm hoping are correct size!) they are still in the boxes. If you pursue this route get in touch. Also bought a couple of lip seals of the (hopefully!) right dimensions too.
