I have a citroen c4 grand spacetourer and wondered if anyone could tell me if it has active lane departure warning as this appears on the settings but doesn't seem to do anything, it has been back to the garage (for various things) and they have said it doesn't have it.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Is there a build sheet available please?
Factory fitted equipment
- x 6956
Re: Factory fitted equipment
Hi Tom
Unfortunately not, the option you are referring to was part of an option pack for this year (April 2019).
It was only available on Feel and Flair Trim levels as an option and part of the Driver Assistance Package 4 which included:
There were other option packs available like the 'Safety Pack Plus' for this year that contained a few of the above options, but not the Active Radar.
All models have a set specification and then there are option packs - which are specific to the base specification (not all trim levels can have all the same option packs). I hope this answers your query. With reference to your vehicle, you have only got the programmable Cruise Control, but no ARTIV radar.
Here's your build sheet
- Active Radar Guided Cruise Control with Stop Function
- Active Safety Brake
- Active Lane Departure Warning System
- Active Blind Spot Monitoring System
- Speed Limit Recognition System
- Driver Attention Alert System
- Intelligent Beam Headlights
- Electrochrome Rear View Mirror
| Vehicle Characteristics | |
| Vehicle family | C4 PICASSO / C4 SPACETOURER (B78) |
| AS/RP N° | 15446 FV 2 0713 |
| Warranty Start Date | 29/03/2019 |
| Engine serial number | 10 Q3BB 0294203 |
| BER | e2*2007/46*0356*19 |
| P4A | 9835919199 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C4 PICASSO / C4 SPACETOURER (B78) |
| SILHOUETTE | ESTATE - LEISURE |
| TRIM LEVEL | HIGH HIGH |
| ENGINE | DV5RC 96KW 1.5L DIESEL |
| TRANSMISSION | STT TYPE 6-SPEED MANUAL GEARBOX |
| PAINT TYPE | STANDARD FLAT EXT TRIM TYPE |
| BODY COLOUR | EXY - ONYX BLACK PAINT |
| INTERIOR TRIM TYPE | TRIM.FINN VELOUR "1H" |
| UPHOLSTERY COLOUR | "FR" |
| GEARBOX (CHARACTERISTICS) | ML6CO |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | DV TYPE ENGINE |
| ROOF (EXT. ASPECT) | WITHOUT ROOF COLOUR APPEARANCE |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| BADGE | WITHOUT BADGE |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.2 ENGINE EMISSION CONTROL |
| SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
| CAPACITY | 1500 CM3 |
| CATALYTIC CONVERTER | CATALYTIC CONVERTER BELOW 50PPM |
| FUEL TANK | FUEL TANK WITH LOCATING TAB |
| OPTIMISATION OF VEHICLE’S CONSUMPTION | INTERMEDIATE FUEL CONSUMPTION OPTIMISATION |
| COOLING MOTOR | RADIATOR 28DM2 - EP18 BRAZED ALU |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| POWER VARIATION (ENGINE) | PUISSANCE MOTEUR 96KW 300NM |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" SELF-DIAGNOSIS |
| DEVICE (ANTIPOLLUTION) | EXHAUST GAS RECYCING "EGR" + EXCHANGER |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1 2-SPEED FAN 95W AERO |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITH STOP AND START STARTER |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 17 X 71 |
| WHEEL STYLE | 17-INCH AQUILLON BLACK ALLOY WHEEL 7 J17 CH 5-50 |
| CLUTCH | HYDRAULIC CLUTCH |
| RIM/TYRE SIZE | 17 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 205/55 R17 95V REINFORCED TYRE |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION |
| GEARBOX TYPE | ML6C |
| Suspension-Steering-Brakes | |
| REAR ANTI-ROLL BAR | STIFFNESS 30000 NM/RAD |
| STEERING COLUMN | MANUALLY ADJUSTED STEERING COLUMN |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 23 HOLLOW |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
| SUSPENSION | NORMAL SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| STEERING (OPERATION) | LOW POWER DOUBLE PINION ELECTRIC POWER STEERING |
| PEDAL BRACKET (TYPE) | SIMPLE STANDARD PEDAL BRACKET |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | FR ROOF+GPS+DIG+INTEGRATED+GSM |
| FINISHER (SELF-ADHESIVE) | GLOSS BLACK REAR SURROUND TRIM |
| SIDE MOULDINGS (DIMENSION) | WITHOUT SIDE PROTECTORS+CHROME FRONT SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| UNDERBODY SHIELD | WITHOUT PROTECTION UNDER BODY |
| INDICATORS | SIDE MARKER LIGHTS |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| DRAUGHT EXCLUSION | FR AND RR DOOR AERODYNAMIC SEALING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN |
| WINDSCREEN WIPER | 2 SPEED INTERMITTENT+AUTOMATIC CADENCING |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITH ROOF WINDOW |
| BUMPER | BODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | MOUNTING WITH ROOF BARS |
| FRONT FOGLAMP | FOG LAMPS WITH CORNERING LIGHT |
| PANORAMIC VISUAL AID | WITHOUT PANORAMIC VISUAL AID |
| SPARE WHEEL | SPACE-SAVING SPARE WHEEL |
| EXTERIOR ACCESSORIES | BODY-COLOURED EXTERIOR HANDLE |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | WITHOUT EXTERIOR MIRROR SPECIAL FEATURE |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| WINDOW (TYPE) | LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS + BOOT + HANDS FREE STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| FRONT HEAD RESTRAINT | SLEEP HINGED FRONT HEAD RESTRAINT |
| SUPPLEMENTARY SEAT | 2 PLACES SUPPLEMENT SEPAR SEATS |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| LUGGAGE COVER | LUGGAGE COVER + WINDSTOP |
| REAR SEATBELT | RR SEAT BELT 5 INERT REELS 3 PTS + FASTEN WARN LGH |
| FRONT SEATBELT | PYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM |
| ASHTRAY | WITHOUT ASHTRAY |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GEAR SELECTOR | FLOOR GEAR CONTROL |
| CONSOLE | CONSOLE LONG+STORAGE |
| DRIVING POSITION | RIGHT HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| AIR EXTRACTOR | WITHOUT AIR EXTRACTOR |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | WITH GLOVEBOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | AUTO BOOT LIGHT OR LOAD VOL SWITCH |
| DASHBOARD EQUIPMENT | UPPER PART PEARLESCENT ARDOISE GREY |
| INT. TRIM AND EQUIPMENT VARIATION | CLOTH INTERIOR EQUIPMENT TRIM |
| MISC. INT. LAMPS | LIGHTING BY LEDS |
| WORK TABLE | WITH WORK TABLE |
| LOAD SPACE TRIM | FOAM BOOT MAT + SOUNDPROOFING |
| UNDERSEAT STORAGE | 2 UNDER SEAT STORAGE DRAWERS |
| INSTRUMENT PANEL (CHARACTERISTICS) | DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS |
| DOOR TRIM | DECOR GLOSS VARNISH |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS |
| ADDITIONAL BLOWER | WITH ADDITIONAL PULSE |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT ADJUSTMENT PASSENGER SPACER |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER LUMBAR ADJUSTMENT |
| FRONT PASSENGER SEAT FOLDING | WITH FOLD PASS FRONT SEATING |
| FRONT SEAT ARMREST | DRIVER ANT PASSENGER FRONT ARMREST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| STOWAGE BIN | FLAPS IN FLOOR |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
| HEADLAMP BULBS | HALOGEN BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY | DGT TOUCHSCREEN+12" DFT DISPLAY |
| OIL GAUGE | W/O OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S FOOTWELL + DOOR TRIM PAD LIGHTING |
| REAR PASSENGER PROTECTION | W/O RR PASSENGER PROTECTION |
| ELECTRIC WINDOW (OPERATION) | DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| COURTESY LAMP | CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITH WIFI |
| RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | NET SEAT BACK STORAGE POCKET |
| CARPET COVER | CARPET MAT 1 |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| COOLANT LEVEL WARNING LAMP | NO WATER LEVEL WARNING |
| OBSTACLE DETECTION SYSTEM | FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK |
| LATERAL BLINDS | SIDE BLINDS |
| TRIM ADAPTATION | KNOB PVC + CHROME DISC + GAITER IN PVC SURPI |
| FLOOR MAT | FR + RR MATS |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | LEATHER STEER WHEEL 4 BRANCHS |
| SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| REAR VIDEO SCREEN | WITHOUT REAR VIDEO SCREEN |
| CHILD OBSERVATION INTERIOR MIRROR | INTERIOR CHILD MONITORING MIRROR |
| AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
| Electrical | |
| ALTERNATOR | ALTERNATOR 150 AMP |
| BATTERY | BATTERY L3 760 70AH EFR 760 EN EF |
| STARTER MOTOR | STOP AND START BY STARTER |
| SPECIAL LIGHTING | FRONT DAY RUNNING LIGHT (DRL) |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| MULTIPLEXING | MODIFIED ECONOMY ELECTRICAL ARCHITECTURE |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF LIGHTS |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| MODIF. DURING MODEL YEAR | 7EME MODIFICATION MINEUR |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19,3DM2 THICKNESS 12 |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| AIR CONDITIONING PIPES | IHX TECHNOLOGY AIR CONDITIONING PIPES |
| RADIO HEADPHONE SOCKET | TRIPLE ACCESSORIES SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| SET OF KEYS | SET OF BADGE KEYS + BACK-UP KEY |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
Cfrtom
Thank you for your reply it's appreciated.
It is really confusing as to why the option to switch it on and off is on the screen, surely if it's not there it shouldn't be there.
- x 1938
Perhaps someone who didn't know better tried to activate an option that wasn't really there?
