Factory fitted equipment
Cfrtom
Unread post by Cfrtom »
I have a citroen c4 grand spacetourer and wondered if anyone could tell me if it has active lane departure warning as this appears on the settings but doesn't seem to do anything, it has been back to the garage (for various things) and they have said it doesn't have it.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Is there a build sheet available please?
x 6950
Re: Factory fitted equipment
Hi Tom
Unfortunately not, the option you are referring to was part of an option pack for this year (April 2019).
It was only available on Feel and Flair Trim levels as an option and part of the Driver Assistance Package 4 which included:
  • Active Radar Guided Cruise Control with Stop Function
  • Active Safety Brake
  • Active Lane Departure Warning System
  • Active Blind Spot Monitoring System
  • Speed Limit Recognition System
  • Driver Attention Alert System
  • Intelligent Beam Headlights
  • Electrochrome Rear View Mirror
This would of been a £1,160 option cost on the Feel Trim and £710 for the Flair Trim.
There were other option packs available like the 'Safety Pack Plus' for this year that contained a few of the above options, but not the Active Radar.
All models have a set specification and then there are option packs - which are specific to the base specification (not all trim levels can have all the same option packs). I hope this answers your query. With reference to your vehicle, you have only got the programmable Cruise Control, but no ARTIV radar.
Here's your build sheet
Vehicle Characteristics
Vehicle familyC4 PICASSO / C4 SPACETOURER (B78)
AS/RP N°15446 FV 2 0713
Warranty Start Date29/03/2019
Engine serial number10 Q3BB 0294203
BERe2*2007/46*0356*19
P4A9835919199
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 PICASSO / C4 SPACETOURER (B78)
SILHOUETTEESTATE - LEISURE
TRIM LEVELHIGH HIGH
ENGINEDV5RC 96KW 1.5L DIESEL
TRANSMISSIONSTT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPESTANDARD FLAT EXT TRIM TYPE
BODY COLOUREXY - ONYX BLACK PAINT
INTERIOR TRIM TYPETRIM.FINN VELOUR "1H"
UPHOLSTERY COLOUR"FR"
GEARBOX (CHARACTERISTICS)ML6CO
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)DV TYPE ENGINE
ROOF (EXT. ASPECT)WITHOUT ROOF COLOUR APPEARANCE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEWITHOUT BADGE
TRIM LEVELHIGH HIGH
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.2 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY1500 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER BELOW 50PPM
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONINTERMEDIATE FUEL CONSUMPTION OPTIMISATION
COOLING MOTORRADIATOR 28DM2 - EP18 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)PUISSANCE MOTEUR 96KW 300NM
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION)EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 2-SPEED FAN 95W AERO
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE17-INCH AQUILLON BLACK ALLOY WHEEL 7 J17 CH 5-50
CLUTCHHYDRAULIC CLUTCH
RIM/TYRE SIZE17 INCH TYRE FITMENT
TYRE (SIZE, TYPE)205/55 R17 95V REINFORCED TYRE
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPEML6C
Suspension-Steering-Brakes
REAR ANTI-ROLL BARSTIFFNESS 30000 NM/RAD
STEERING COLUMNMANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR DIAMETER 23 HOLLOW
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)SIMPLE STANDARD PEDAL BRACKET
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
AERIALFR ROOF+GPS+DIG+INTEGRATED+GSM
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (DIMENSION)WITHOUT SIDE PROTECTORS+CHROME FRONT SIDE SILL
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
UNDERBODY SHIELDWITHOUT PROTECTION UNDER BODY
INDICATORSSIDE MARKER LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
DRAUGHT EXCLUSIONFR AND RR DOOR AERODYNAMIC SEALING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN
WINDSCREEN WIPER2 SPEED INTERMITTENT+AUTOMATIC CADENCING
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITH ROOF WINDOW
BUMPERBODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
SPARE WHEELSPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIESBODY-COLOURED EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
HANDS FREE ACCESS AND STARTINGFRONT ACCESS + BOOT + HANDS FREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITH THEFT PROTECTION ALARM
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTSLEEP HINGED FRONT HEAD RESTRAINT
SUPPLEMENTARY SEAT2 PLACES SUPPLEMENT SEPAR SEATS
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
LUGGAGE COVERLUGGAGE COVER + WINDSTOP
REAR SEATBELTRR SEAT BELT 5 INERT REELS 3 PTS + FASTEN WARN LGH
FRONT SEATBELTPYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM
ASHTRAYWITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORFLOOR GEAR CONTROL
CONSOLECONSOLE LONG+STORAGE
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
AIR EXTRACTORWITHOUT AIR EXTRACTOR
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGWITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTINGAUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENTUPPER PART PEARLESCENT ARDOISE GREY
INT. TRIM AND EQUIPMENT VARIATIONCLOTH INTERIOR EQUIPMENT TRIM
MISC. INT. LAMPSLIGHTING BY LEDS
WORK TABLEWITH WORK TABLE
LOAD SPACE TRIMFOAM BOOT MAT + SOUNDPROOFING
UNDERSEAT STORAGE2 UNDER SEAT STORAGE DRAWERS
INSTRUMENT PANEL (CHARACTERISTICS)DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIMDECOR GLOSS VARNISH
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
ADDITIONAL BLOWERWITH ADDITIONAL PULSE
PASSENGER COMPARTMENT SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT FOLDINGWITH FOLD PASS FRONT SEATING
FRONT SEAT ARMRESTDRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISCWITHOUT COMPACT DISC
STOWAGE BINFLAPS IN FLOOR
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDGT TOUCHSCREEN+12" DFT DISPLAY
OIL GAUGEW/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER’S FOOTWELL + DOOR TRIM PAD LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
ELECTRIC WINDOW (OPERATION)DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
COURTESY LAMPCONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
WIFIWITH WIFI
RADIO RECEIVERDIGITAL CONNECTED NAVIGATION
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLPROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)NET SEAT BACK STORAGE POCKET
CARPET COVERCARPET MAT 1
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIOMONO RADIO TUNER
COOLANT LEVEL WARNING LAMPNO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEMFR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK
LATERAL BLINDSSIDE BLINDS
TRIM ADAPTATIONKNOB PVC + CHROME DISC + GAITER IN PVC SURPI
FLOOR MATFR + RR MATS
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLDEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELLEATHER STEER WHEEL 4 BRANCHS
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREENWITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRRORINTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATORALTERNATOR 150 AMP
HORNSHORNS-HARMONY
BATTERYBATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTORSTOP AND START BY STARTER
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
MULTIPLEXINGMODIFIED ECONOMY ELECTRICAL ARCHITECTURE
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEAR7EME MODIFICATION MINEUR
CONDENSER (SPECIFICATIONS)CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESIHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETTRIPLE ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
Cfrtom
Thank you for your reply it's appreciated.
It is really confusing as to why the option to switch it on and off is on the screen, surely if it's not there it shouldn't be there.
x 1953
Perhaps someone who didn't know better tried to activate an option that wasn't really there?
