P0495 cooler issue
GORAX
x 14
P0495 cooler issue
Unread post by GORAX »
Hello everyone, I have another P error while driving. It is error P0495. I was able to delete the error, but I think it's a matter of time before it comes back. Where should I start my search? Replace relay or fan?
GOOGLE TRANSLATE
Huskyxantia
x 929
Re: P0495 cooler issue
Unread post by Huskyxantia »
Ohms test both , then pop your readings up , but ... I'd change the relay (if it was my car) there not to badly priced.
:-D
GORAX
x 14
Thanks will try!
GOOGLE TRANSLATE
GORAX
x 14
do I have to learn it with lexia?
GOOGLE TRANSLATE
GORAX
x 14
Is this the correct part?
https://www.ebay.de/itm/363204389941?_s ... BM1riD-KRl
According to the VIN number it is. But is it also the solution to my problem if I just want to change the relay?
GOOGLE TRANSLATE
Huskyxantia
x 929
That looks the right one
:-D
Huskyxantia
x 929
Once replaced test it with lexia. Normally these parts are just like plug & play.
:-D
GORAX
x 14
I will report after change!
GOOGLE TRANSLATE
GORAX
x 14
Change issue deleted all good
GOOGLE TRANSLATE
Huskyxantia
x 929
Well done
:-D
