Citroen C3 RD45 stereo system
APTinSnail
Unread post by APTinSnail »
Hi All,
I have an OEM RD45 stereo in a 2012 Citroen C3.
I don't have the handbook, and the radio powers on ok, but it makes a constant beeping sound which I believe means that a PIN code must be entered.
I removed the radio from the dash to try and identify the serial no, and there are 2 stickers showing various part numbers, model nos etc...Brand is Continental but I'm not sure which one is the serial number.
Does anyone know the format of the serial number or can it be accessed via the radio menus ?
Cheers.
Mr AP TinSnail
PaulC5
x 718
Re: Citroen C3 RD45 stereo system
Unread post by PaulC5 »
If the radio is beeping it must not be the one originally installed when the car was made. To stop this it will need to be coded to the car vin with a diagnostic using Citroen diagnostic equipment. It will not have a pin and the numbers on the radio are not relevant to stop the beeping. Other option is to put the original radio back. You can read/save/print the hand books from this topic viewtopic.php?t=63208
x 6950
As above - it's VIN coded, so no pin, so has likely been replaced with another unit.
Have a look at our list of members who have offered Lexia / Peugeot Planet 2000 / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
APTinSnail
Thanks ever so much for the advice.
Much appreciated.
