C5 aircross 2019 half of the heating is working
bard1988
Unread post by bard1988 »
Hello.
So I have some weird issue that only half of my heating are blowing warm air, the left ones are ok-ish and the right ones blow much cooler air.
What do you think might be the issue?
I was told it might have something to do with the heating Matrix.. I tried finding a guide how to replace it and didn't find it online, can anyone share a video/manual?
Thank you in advance
x 6947
Re: C5 aircross 2019 half of the heating is working
Hi, before you start replacing parts, you need to have it properly diagnosed. The coolant system needs checking and may have an air lock - especially if somebody has attempted to replace the coolant without knowing the proper methods of doing this and the essential ge-gassing / bleeding which is part of the operation. If not done properly you will get air locks.
It would be highly unlikely for this late a vehicle to start having Heater Matrix issues within 5 years.
bard1988
Thanks for the reply
Can you share a guide or video that explains the procedure?
x 6947
Sorry, I don't have this specific procedure.
alexmishev
Unread post by alexmishev »
Hello, have you solved the heater problem? I have exactly the same one. Thabks in advance.
