P0691 and P0483
miruim
P0691 and P0483
Unread post by miruim »
Hello and a Great 2025 to all.
I have a c5 x7 9hz Motor.
One moth ago i found errors with diagbox P0691 and P0483 .
All suposed to be a cooling fan problem. The fan works in the normal speed, and when i turn the AC On the the Fan starts working in High speed.
I have tested with diagbox the normal speed and works good. When i test the high speed, the fan begins and then stops.
I have checked all wires till ECU and all are ok.
I have checked with a new one cooling Fan and the errors are the same. the P0483 i can clear, but sometimes it appairs again.
the water is cold and i dont know how to solve this problem .
Can someone help me with a clue ?
Best regards to all
miruim
Re: P0691 and P0483
any clue that can help me , please ??
x 6950
Re: P0691 and P0483
Both these errors relate to open and short circuits - so did you replace the electronic cooling fan unit and not just the fan? If so, check the wiring.
Fault Code: P0691
Description of Fault:
  • Fast speed cooling fan control: Short-circuit to earth or short-circuit to the battery plus or excessive temperature.
    Description of the diagnostics: The ECU detects a short-circuit to the battery plus or a short-circuit to earth or an excessive temperature on the fast speed cooling fan control channel for 5 seconds.
Conditions for Fault to clear:
  • Ignition on
Downgrade Modes whilst Fault is active:
  • Diminution of the coolant temperature thresholds to cut the aircon compressor
Symptoms:
  • Fan unit at high speed
  • Water temperature warning
    Engine overheating
Suspect Areas:
  • Electrical harness
  • Connector
Fault Code: P0483
  • Cooling Function Incorporated in the ECU ( electric cooling fan unit): Open circuit. The line is in open circuit for more than 5 seconds
  • Ignition on
Symptoms:
  • The cooling fan to operate permanently at maximum speed
  • Battery discharged
Suspect Areas:
  • Electric cooling fan unit
  • Connector
miruim
Re: P0691 and P0483
I have changed all the wires and relay, not just the fan.. Checked the wires to the ECU and all are ok.
x 6950
Re: P0691 and P0483
Well I can only tell you what the code is officially relating to, so either there is something else in the control unit not working or it's just not happy about it.
