Hello and a Great 2025 to all.
I have a c5 x7 9hz Motor.
One moth ago i found errors with diagbox P0691 and P0483 .
All suposed to be a cooling fan problem. The fan works in the normal speed, and when i turn the AC On the the Fan starts working in High speed.
I have tested with diagbox the normal speed and works good. When i test the high speed, the fan begins and then stops.
I have checked all wires till ECU and all are ok.
I have checked with a new one cooling Fan and the errors are the same. the P0483 i can clear, but sometimes it appairs again.
the water is cold and i dont know how to solve this problem .
Can someone help me with a clue ?
Best regards to all
P0691 and P0483
miruim
Re: P0691 and P0483
any clue that can help me , please ??
- x 6956
Re: P0691 and P0483
Both these errors relate to open and short circuits - so did you replace the electronic cooling fan unit and not just the fan? If so, check the wiring.
| Fault Code: | P0691 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0483 |
| Symptoms: |
| Suspect Areas: |
miruim
Re: P0691 and P0483
I have changed all the wires and relay, not just the fan.. Checked the wires to the ECU and all are ok.
- x 6956
Re: P0691 and P0483
Well I can only tell you what the code is officially relating to, so either there is something else in the control unit not working or it's just not happy about it.
