Hi Marc
Is it possible to get a copy of the build-sheet for my DS5 please? The VIN is VF7**************[VIN obfuscated, can be read by forum staff]. I am particularly interested in the ECU type/model number and I'm hoping that this is included.
Please let me know if I need to make a contribution for this.
Hope you are having a restful Christmas..
Many thanks
Andy
DS5 Build-sheet request.
- x 6845
Re: DS5 Build-sheet request.
Sure, here you go:
A build sheet doesn't include the specifics of ECUs, only the engine ECU variant for the most part. However if you require a specific part number, your donor membership status entitles you to request this info.
So assuming you mean Engine ECU, you have a Delphi Engine ECU:
(1) Engine Management ECU (to be configured), part: 1614391580, £1793.18
Engine ECU (Standard Exchange ECU - to be configured), part: 1677656380, £1050.68
Vehicle Characteristics | |
Vehicle family | DS 5 |
AS/RP N° | 14759 89 3 0022 |
Warranty Start Date | 29/09/2017 |
Engine serial number | 10 DYZM 4032571 |
OPB | 003O |
BER | e2*2007/46*0092*16 |
P4A | 9802593999 |
General Information | |
PRODUCT TYPE | PASSENGER CAR |
COMMERCIAL MARQUE/COMPONENT TYPE | DS |
VEHICLE FAMILY | DS 5 |
SILHOUETTE | 5 DOOR SALOON |
TRIM LEVEL | UPPER MEDIUM |
ENGINE | DIESEL DW10FC FAP 132KW |
TRANSMISSION | AUTO GBOX 6-SPEED STT |
PAINT TYPE | METALLIC LACQUER PAINT |
BODY COLOUR | KTV - BLACK PEARL PAINT |
INTERIOR TRIM TYPE | NAPPA LEATHER "4H" |
UPHOLSTERY COLOUR | "FW" |
DEFINITION TO FOLLOW | MID-LIFE |
ENGINE (TYPE) | EW/DW |
Fuel Supply-Engine | |
FUEL SUPPLY | DIRECT EXCHANGE TURBO INJECTION |
DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
CYLINDER BLOCK (MATERIAL) | CRANKCASE CAST IRON |
FUEL | DIESEL GRADE DA/DE/DE+ |
EMISSIONS STANDARD (ENGINE) | EURO 6.1 ENGINE EMISSION CONTROL |
CAPACITY | 2000 CM3 |
OIL COOLER | ENGINE+GBOX OIL/WATER EXCHANGER |
FUEL TANK | FUEL TANK WITH LOCATING TAB |
OPTIMISATION OF VEHICLE’S CONSUMPTION | NORMAL |
CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN TYPE |
EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
VEHICLE TECHNICAL DEPOLLUTION | EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL |
PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
FAN | 1 FAN 2 SPEEDS 160W |
FUEL VAPOUR RETRIEVAL | WITHOUT PETROL VAPOUR RECUPERATION |
INJECTION ASSOCIATED VARIANT | MOUNTING DELPHI |
DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
TANK FILTER | RESERVOIR FILTER INTERIOR |
STOP AND START | STOP AND START ALTERNATOR STARTER |
Gearbox Transmission | |
FINAL DRIVE RATIO | CP 15 X 53 |
WHEEL STYLE | CAIRNS 19-INCH WHEEL |
CLUTCH | WITHOUT CLUTCH |
DIFFERENTIAL (GEARBOX) | W/O GEARBOX DIFF |
RIM/TYRE SIZE | 19 INCH TYRE FIT |
TYRE (SIZE, TYPE) | 235/40 R19 96W REINFORCED TYRE |
WHEELS FITTED | WHEEL 8" 1/2 |
WHEEL (TYPE) | ALLOY 9 WHEEL FITTING |
INFLATION PRESSURE LOSS INDICATOR | LOSS OF INFLATION PRESSURE INDICATOR EU STANDARD 64.02 |
GEARBOX TYPE | AM6 3 TYPE GEARBOX |
Suspension-Steering-Brakes | |
ABS | WITH ABS BRAKES |
REAR ANTI-ROLL BAR | REAR ANTI ROLL BAR DIAM 27 |
FRONT ANTI-ROLL BAR | FRONT ANTI ROLL BAR DIAM 23,5 |
SUSPENSION | LOWERED SUSPENSION |
DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT | BOSCH 8.1 ESP |
PEDAL BRACKET (TYPE) | PEDAL STANDARD |
Body Fittings | |
TOWBAR | WITHOUT TOWBAR |
HORNS | HORNS-HARMONY |
AERIAL | ROOF AERIAL + GPS + DIGITAL + INTEGRATED |
REAR SPOILER | WITH TAILGATE UPPER SPOILER |
SIDE MOULDINGS (TYPE) | CHROME SIDE PROTECTORS |
SIDE MOULDINGS (DIMENSION) | THIN LAT PROTECTORS+CHROME SILLS |
WHEEL EMBELLISHER (STYLE) | DS CAP |
UNDERBODY SHIELD | WITHOUT PROTECTION UNDER BODY |
INDICATORS | SIDE MARKER LIGHTS |
SILL ILLUMINATION LAMP | WITHOUT SILL ILLUMINATION |
ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
EXT. LOAD RETENTION RING (ATTACHMENT) | BOAT + LORRY EXT LASHING RING |
EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR ELECTRIC-FOLD BACK |
ENGINE BAY SOUNDPROOFING | BULKHEAD SOUNDPROOFING + BONNET + SHORT ACOUSTIC POWER TRAIN |
WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
HEADLAMP WIPER | HEADLAMP WASHWIPE |
FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
ROOF GLASS | WITH FIXED ROOF GLASS |
BUMPER | FR/RR BUMPER STD BODY-COLOURED |
MUDFLAP | WITHOUT MUD FLAPS |
FRONT FOGLAMP | LED FOG LAMPS + CORNERING LAMP |
SPECIAL HEADLAMP (DOUBLE OPTIC) | TWO-TONE MASK |
SPARE WHEEL | WITHOUT SPARE WHEEL |
EXTERIOR ACCESSORIES | CHROME+BODY-COLOURED EXT HANDLE |
BUMPER TRIM | BLACK-PAINTED BUMPER STRIP |
GLASS (APPEARANCE) | FR TINTED WINDOW+DEEPTINTED RR (QUARTER+TAILGATE) |
HANDS FREE ACCESS AND STARTING | WITH HANDS-FREE ACCESS/STARTING |
Interior Fittings | |
ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
CIGAR LIGHTER | FRONT CIGAR-LIGHTER |
REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT | JOINTED FRONT HEADREST |
BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
FRONT SEATBELT | DOUBLE PYROTECHNIC SEAT BELT WITH ALARM |
CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
AIR CONDITIONING | WITH AUTO RECIRCULATION HEATER MATRIX |
SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
GEAR SELECTOR | FLOOR GEAR CONTROL |
DRIVING POSITION | RIGHT HAND DRIVE |
ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
MIRROR LINK | WITH MIRROR LINK |
DASHBOARD EQUIPMENT | PVC DASHBOARD + VISOR |
MISC. INT. LAMPS | AMBIENT LIGHTING |
WORK TABLE | WITH WORK TABLE |
LOAD SPACE TRIM | BOOT CARPET MAT |
INSTRUMENT PANEL (CHARACTERISTICS) | GRADUATION 260 KM/H 160 M/H COLOUR MATRIX |
DOOR TRIM | CLUB LEATHER DECOR |
LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
DRIVER SEAT CONTROL | MEMORY CTRL DRIVERS FRONT SEAT |
FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT ELEC CNTRL |
FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER’S LUMBAR SUPPORT |
COMPACT DISC | MOUNTING COMPACT DISC |
SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM + TRAFFIC INFO |
HEADLAMP BULBS | LED BULB + DISCHARGE BULB |
TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
DISPLAY | DGT7C SCREEN FRONT DISPLAY |
CLOCK | ANALOGUE CLOCK |
FOOTREST | DRIVER’S FOOTREST |
HEATING ELEMENT | HEATED SEAT |
FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
FOOTWELL LIGHTING | DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING |
EXTERIOR REAR VIEW MIRROR (HEATED) | EXT HEATING REAR VIEW MIRROR |
AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
HEADLAMP HEIGHT ADJUSTER | AUTOMATIC HEADLAMP ADJUSTMENT |
DIRECTIONAL HEADLAMP | WITH DIRECTIONAL LIGHTS |
WIFI | WITH WIFI |
RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
REFRIGERATION | AUTOMATIC AIR CONDITIONING |
CRUISE CONTROL | PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER |
INTERIOR REAR VIEW MIRROR | FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR |
CARPET COVER | CARPET MAT 1 |
LOAD SPACE STORAGE | WITHOUT STORAGE COMPARTMENT IN BOOT |
COOLANT LEVEL WARNING LAMP | NO WATER LEVEL WARNING |
OBSTACLE DETECTION SYSTEM | FR RR RADAR OBSTACLE DETECTOR + RR CAMERA |
TRIM ADAPTATION | LEATHER GEAR LEVER KNOB + LEATHER GAITER |
FLOOR MAT | WITH CARPETMAT |
EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
LOCKING CONTROL | CENTRAL DEADLOCKING + AUTOMATIC LOCKING |
STEERING WHEEL | SMOOTH LEATHER STEERING WHEEL |
AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB |
TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT EVOLUTION 2.0 |
Electrical | |
ALTERNATOR | ALTERNATOR ISTT53 |
BATTERY | BATTERY L3 760 70AH EFR 760 EN EF |
STARTER MOTOR | STARTER MOTOR CLASS 6+ |
SPECIAL LIGHTING | AUTOMATIC HEADLAMP ILLUMINATION |
CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF LIGHTS |
Component Manufacturers | |
Miscellaneous | |
SPECIAL SPECIFICATION | STANDARD |
MODIF. DURING MODEL YEAR | MINOR INDEX "05" |
ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
LABEL | WITHOUT LABEL |
RADIO HEADPHONE SOCKET | WITH ACCESSORIES SOCKET |
TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
SIDE IMPACTS | STANDARD SIDE BUMPERS |
REFRIGERANT | AIRCON FLUID 1234 YF |
EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
SURFACE CONDITIONS | GOOD TERRAIN |
