Vin spec look up
RichardDS7
Vin spec look up
Unread post by RichardDS7 »
Would it be possible to get the vehicle spec information with my vin for newly purchased DS7 rivoli.
VIN VR1**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
x 6963
Re: Vin spec look up
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
RichardDS7
Apologies, I don't know how I missed this and thank you. Donation made as requested.
x 6963
Thanks for your Forum donation Richard, give me a few minutes and I'll provide this for you (we've just had another power cut after a week of no power)! Back up (for now).
x 6963
Here you are:
Please also note: There is an after-sales campaign being flagged up on this vehicle from 02/10/2024, with reference code: NJ3 that concerns:
NJ3 - cross carline - Gearbox software
So your gearbox ECU needs updating, so I would get it booked into the dealership and quote your VIN and the code above - the work will be free of charge.
Build Sheet
Vehicle Characteristics
Vehicle familyDS 7 CROSSBACK (X74)
AS/RP N°17186 88 1 0382
Warranty Start Date07/05/2024
Engine serial number10 Q3EJ 1862759
OPB00JV
BERe2*2007/46*0601*25
P4A9831364899
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEDS
VEHICLE FAMILYDS 7 CROSSBACK (X74)
SILHOUETTES.U.V.
TRIM LEVELUPPER MEDIUM
ENGINEDV5RC UE64 1.5 L DIESEL
TRANSMISSIONSTT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPEMETALLIC LACQUER
BODY COLOURECLIPSE BLUE PAINT
INTERIOR TRIM TYPEGRAINED LEATHER "57"
UPHOLSTERY COLOUR"FE"
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)DV TYPE ENGINE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEFAMILY BADGE
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAPWITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.4 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY1500 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER BELOW 50PPM
FUEL TANKNON-PRESSURISED FUEL TANK WITH LOCATING TAB
COOLING MOTORRADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)ENGINE POWER 96KW - 300NM
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLEHOPE 2 19-INCH WHEEL
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE19 INCH TYRE FIT
TYRE (SIZE, TYPE)235/50 R19 103V REINFORCED
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPEATN8 TYPE GEARBOX
Suspension-Steering-Brakes
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 32500 NM/RAD
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTBOSCH 9.3 ESP
STEERING (OPERATION)HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
SIDE MOULDINGS (TYPE)CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION)THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS
WHEEL EMBELLISHER (STYLE)BLACK CAP
EXHAUST TAILPIPEWITHOUT EXHAUST TAIL PIPE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)BOAT EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
WINDSCREEN GLASS (TYPE)HEATED WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
ROOF GLASSWITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH
BUMPERBODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD
NUMBER PLATEWITHOUT LICENCE PLATE
FRONT FOGLAMPNO FRONT FOG LIGHTS
PANORAMIC VISUAL AIDVIDEO PARK 1
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESCHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
BUMPER TRIMBUMPER WITHOUT TRIM
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTINGWITH HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEATSEAT CUSHION+BACK 2/3-1/3 FOLDING
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
CABIN SEATWITHOUT CAB SEAT
LUGGAGE COVERSHELF
ASHTRAYWITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH AUTO RECIRCULATION HEATER MATRIX
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORRAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGLED STORAGE COMPARTMENT + GLOVE BOX LIGHTING
DASHBOARD EQUIPMENTBROWN TEP PU STRIP
MISC. INT. LAMPSMONOCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS)DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTSWITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
ADDITIONAL BLOWERWITH ADDITIONAL PULSE
POLLEN FILTERALLERGEN FILTER
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLPASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENTTILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO
FRONT SEAT ARMRESTCENTRAL ARMREST FLOCKED + PVC
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSLED BULB
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAY12-INCH COLOUR HD TOUCHSCREEN DISPLAY
CLOCKANALOGUE CLOCK
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTRESTALU DRIVER’S FOOTREST
OIL GAUGEW/O OIL LEVEL INDICATOR
HEATING ELEMENTDRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
WIFIWITHOUT WIFI
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLWITH GEAR CHANGE
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
CARPET COVERCARPET MAT 1
LOAD SPACE STORAGEPRE-EQUIPPED FOR RETRACTABLE FLOOR STORAGE
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
TRIM ADAPTATIONLEATHER GEAR LEVER KNOB + LEATHER GAITER
FLOOR MATFR + RR MATS
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELSPLIT LEATHER STEERING WHEEL + DECOR
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKETAUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR CLASS 18 HEA
HORNSHORNS-HARMONY
BATTERYL3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTORSTTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY)STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGERWITHOUT ON-BOARD CHARGER
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
CONDENSER (SPECIFICATIONS)CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONSDUSTY ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESIHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
EMERGENCY WARNING TRIANGLEWITHOUT WARNING TRIANGLE
RichardDS7
Perfect thanks, I know it's cheeky to ask but is this available as a PDF via email/link
Richard
PaulC5
x 650
Unread post by PaulC5 »
If you want to save a copy simply highlight it with your mouse, right click the mouse and click copy and then open a Word blank page and then paste it by again right clicking the mouse. I just tried it and it worked.
x 6963
Just do as Paul suggested, as these are prepared and phpbb coded by me manually. If you have MS Word, you can save it as a PDF.
Petermac50
Unread post by Petermac50 »
Would it be possible to get a full build spec on my 2021 DS & Crossback Vin Number VR1**************[VIN obfuscated, can be read by forum staff] PLEASE
