2020 Berlingo valeo front sensors retrofit
Greyberlingo
Unread post by Greyberlingo »
Hi I’m planning to fit front park to my 2020 Berlingo. It has the valeo module with the 26pin and 18pin plugs. Does anyone have a wiring diagram? I’ve viewed quite a few people have put on but it looks as they refer to, 2 x18pin plugs? Maybe a Bosch system? It’s really only the pin out for the front and should be the 18pin plug. I’m using a vw or audi loom as they will be the same just the pinout might be different at the socket.
The 8k module on eBay is quite reasonable.
x 6945
Re: 2020 Berlingo valeo front sensors retrofit
I don't have this - you won't likely get it on the internet - you'll most likely have to pay PSA for it.
Greyberlingo
Thanks, how do I do that? Do you have a link?
x 6945
No. you'll need to contact your dealer.
