Hi I’m planning to fit front park to my 2020 Berlingo. It has the valeo module with the 26pin and 18pin plugs. Does anyone have a wiring diagram? I’ve viewed quite a few people have put on but it looks as they refer to, 2 x18pin plugs? Maybe a Bosch system? It’s really only the pin out for the front and should be the 18pin plug. I’m using a vw or audi loom as they will be the same just the pinout might be different at the socket.
The 8k module on eBay is quite reasonable.
2020 Berlingo valeo front sensors retrofit
- x 6955
Re: 2020 Berlingo valeo front sensors retrofit
I don't have this - you won't likely get it on the internet - you'll most likely have to pay PSA for it.
Greyberlingo
Thanks, how do I do that? Do you have a link?
- x 6955
No. you'll need to contact your dealer.
