Hi again,
is it normal that the fan radiator is active (spinning) when starting the cold engine? My car has been sitting in the garage for 2 days at ~12 Degree Celsius when starting it and noticing the fan spinning.
I thought the fan would only activate one the cool and reaches a certain temperature?
C5A PureTech 180 - Radiator fan active right after starting cold engine?
zakazak
- x 4
- x 6950
Re: C5A PureTech 180 - Radiator fan active right after starting cold engine?
Yes, if the Climate control / Air Conditioning is on or on 'Auto', then low speed fan will be running.
zakazak
- x 4
Thank you - that explains itGiveMeABreak wrote: 01 Dec 2024, 11:57 Yes, if the Climate control / Air Conditioning is on or on 'Auto', then low speed fan will be running.
