Ad blue
Mickw91
Ad blue
Unread post by Mickw91 »
Looking for some advice/ help please. I have checked to see how many miles left before ad blue top, by starting car and pressing the service button. It showed 1700 miles, so I decided to put In 10 litres before it starts to show the 1500 mile reminder. When I now check it again, after start up and pressing service button, the ad blue light displays and it is still showing 1700 miles. I have given the car a half an hour drive on the motorway, to see if this would help reset it, but it hasn't made any difference. Would appreciate any help/ advice. Thank you.
x 1056
Re: Ad blue
Unread post by wheeler »
I used a Peugeot Expert for around a year & done loads of miles in it, It would never show anything above 1700 miles left. Only started counting down when it got below this, If it filled the tank up it would just go back to 1700 again & stay there till it got low again, It used adblue at a normal rate & (amazingly) never had any issues with the adblue system.
I assumed the counter operation was normal based on this.
x 6956
Re: Ad blue
This is normal behaviour - countdown only reduces when it falls below this level. It’s all in your owners manual.
Mickw91
Re: Ad blue
wheeler wrote: 27 Nov 2024, 16:20 I used a Peugeot Expert for around a year & done loads of miles in it, It would never show anything above 1700 miles left. Only started counting down when it got below this, If it filled the tank up it would just go back to 1700 again & stay there till it got low again, It used adblue at a normal rate & (amazingly) never had any issues with the adblue system.
Thank you for your help, 🤞it will be ok. Cheers
Mickw91
Re: Ad blue
GiveMeABreak wrote: 27 Nov 2024, 16:25 This is normal behaviour - countdown only reduces when it falls below this level. It’s all in your owners manual.
Ok, cheers. Didn't get an owners manual when I got the car, but thanks for replying.
x 8085
Re: Ad blue
As one Mick to another you may find this helpful:
https://www.ebay.co.uk/itm/166805440868 ... 6465788868
Mickw91
Re: Ad blue
mickthemaverick wrote: 27 Nov 2024, 19:42 As one Mick to another you may find this helpful:
Cheers
PaulC5
x 675
Re: Ad blue
Unread post by PaulC5 »
You can access the owner's manual via this topic and then save/print/read them. Open the later ones as pdf top right to be able to save. Click on the flag top right to select your language then choose your car. viewtopic.php?t=63208
x 6956
Re: Ad blue
.... yes, don't be paying some idiot for something that is free and provided by the manufacturer - see my post in Paul's link above on how to download one yourself.
Mickw91
Re: Ad blue
GiveMeABreak wrote: 28 Nov 2024, 15:00 .... yes, don't be paying some idiot for something that is free and provided by the manufacturer - see my post in Paul's link above on how to download one yourself.
Cheers
Mickw91
Re: Ad blue
PaulC5 wrote: 27 Nov 2024, 21:50 You can access the owner's manual via this topic and then save/print/read them. Open the later ones as pdf top right to be able to save. Click on the flag top right to select your language then choose your car. viewtopic.php?t=63208
Cheers
