C5 Aircross 2022 1.2 Puretech correct oil
lalakis
Unread post by lalakis »
Hello i am confused if i have to use 5W30 or 0W20 for my 2022 facelift Citroen C5 Aircross EAT8 1.2 Puretech 130hp. Can you please advise? My VIN number is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
Oldpug
x 93
Re: C5 Aircross 2022 1.2 Puretech correct oil
Unread post by Oldpug »
Use 0W-30, Mobile Super3000 looks like the best choice.
Peugeot/Citroen say change the oil and filter every 15000kms or 1 Year. Others are saying half that now.
An oil change twice a year is not going to break the bank.
Don’t forget, it’s most to inspect the cam belt regularly on these “wet belt” engines.
PaulC5
x 669
Unread post by PaulC5 »
There is a guide here to the correct oils but still best to be checked using your VIN since Citroen have been changing specs recently.
Having said that, since your car is still under warranty I would get your dealer to change the oil and do the timing belt checks, particularly since the Puretech engines have previously had problems with timing belts.
viewtopic.php?t=75919
x 6955
lalakis wrote: 27 Nov 2024, 05:20 Hello i am confused if i have to use 5W30 or 0W20 for my 2022 facelift Citroen C5 Aircross EAT8 1.2 Puretech 130hp. Can you please advise? My VIN number is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
5W30 that meets specification: FPW9.55535/03 is what you require officially based on your VIN.
x 6955
Oldpug wrote: 27 Nov 2024, 09:52 Use 0W-30, Mobile Super3000 looks like the best choice.
That's not the correct oil. :wink:
