Berllingo 1.6HDi Faults P0093, P0087 and P0001
Philc3008
Unread post by Philc3008 »
I'm new to this group and have taken on the task of trying to mend my son's Berlingo 1.6HDi which broke down recently and would not restart.
Car just spluttered and stopped with cloud of smoke behind. TRurned over but smoke coming from engine area. Fault codes P0001, P0087, P0093 seen when mechanic came.
Once I had it home, found that Injector 43 was loose which was probably where smoke/ diesel vapour was coming from - tightened up but still no good
Saw a post on this forum and so have changed the fuel filter but still no start - a coupler of fires but nothing else.
Any thoughts please as am reluctant to scrap it (which son thinkls)
x 1485
Re: Berllingo 1.6HDi Faults P0093, P0087 and P0001
Welcome along
Have you checked the cambelt is intact? Really you need live data so that you can see which of crank signal, cam synch and fuel pressure is missing - although the codes are pointing to it being fuel pressure. Possibly the fuel pressure sensor or regulator on the pump has failed leading to no rail pressure.
Philc3008
Richard,
I have checked the cam belt and it is intact.
Next thought is fuel pressure sensor on common rail or fuel pump. Don't know where either of them are though!
A lot to learn
Phil
Huskyxantia
x 901
Unread post by Huskyxantia »
:-D
Huskyxantia
x 901
:-D
Philc3008
Thanks for the responses and particularly where the pressure sensor is. A bit of a pig to get out I should think.
How does the air box come out please. And also where is the fuel pump if I find that it is faulty?
Huskyxantia
x 901
Fuel pump in tank get to it under backseat big nylon screw bung
Air box , bolt or screwed some are hex , youtube has tons of videos for these great cars.
:-D
Philc3008
Thanks Husky
