Bolt dimensions
Ammonia2418
Bolt dimensions
Unread post by Ammonia2418 »
Does anyone know the dimensions for the bolt listed as "C" here
https://catalogs.ssg.asia/peugeot/?lang ... T1NDSCA%3D
I have this caliper bolt that has rounded off, and I do not want to buy a caliper repair kit which has this bolt included, I just need the bolt itself but cant find info on this bolt so I can just pick one up at the hardware store. Anyone have any info ?
x 8421
Re: Bolt dimensions
The bolt is safety-critical and likely to be of high tensile steel... You may find one that will fit at a hardware store but it's unlikely to be of the correct specification.
I'd not risk it. One's life can depend upon correctly functioning brakes.
x 1493
Re: Bolt dimensions
You often get them with new pad sets. Otherwise, remove the bottom bolt, measure it, and then get one to suit. Note the spec on the existing bolt (if you can read the number!) - these will be high tensile bolts of some sort.
Steve Walsh
x 518
Re: Bolt dimensions
Unread post by Steve Walsh »
The bolt is M8 x 1.0 pitch 22mm long. 10.9 Grade High Tensile...
1.0 Pitch metric fine not the normal hardware stock, neither is 10.9 grade
x 1996
Re: Bolt dimensions
Unread post by Stickyfinger »
I note they are included the brake pad set from Peugeot/Citroen....
Ammonia2418
Re: Bolt dimensions
Steve Walsh wrote: 08 Nov 2024, 09:08 The bolt is M8 x 1.0 pitch 22mm long. 10.9 Grade High Tensile...
Thats a very specific answer, thank you so much.
Thanks to everyone else for all the help aswell.
Appreciate it!
Oldpug
x 94
Re: Bolt dimensions
Unread post by Oldpug »
As citroJim has said, they are very special calliper only bolts. So why not buy the kits, items 5 or 6 in the link.
x 1996
Re: Bolt dimensions
