Does anyone know the dimensions for the bolt listed as "C" here
https://catalogs.ssg.asia/peugeot/?lang ... T1NDSCA%3D
I have this caliper bolt that has rounded off, and I do not want to buy a caliper repair kit which has this bolt included, I just need the bolt itself but cant find info on this bolt so I can just pick one up at the hardware store. Anyone have any info ?
Bolt dimensions
- x 8431
Re: Bolt dimensions
The bolt is safety-critical and likely to be of high tensile steel... You may find one that will fit at a hardware store but it's unlikely to be of the correct specification.
I'd not risk it. One's life can depend upon correctly functioning brakes.
- x 1497
Re: Bolt dimensions
You often get them with new pad sets. Otherwise, remove the bottom bolt, measure it, and then get one to suit. Note the spec on the existing bolt (if you can read the number!) - these will be high tensile bolts of some sort.
Steve Walsh
- x 518
Re: Bolt dimensions
The bolt is M8 x 1.0 pitch 22mm long. 10.9 Grade High Tensile...
1.0 Pitch metric fine not the normal hardware stock, neither is 10.9 grade
- x 2006
Re: Bolt dimensions
I note they are included the brake pad set from Peugeot/Citroen....
Ammonia2418
Re: Bolt dimensions
Thats a very specific answer, thank you so much.Steve Walsh wrote: 08 Nov 2024, 09:08 The bolt is M8 x 1.0 pitch 22mm long. 10.9 Grade High Tensile...
Thanks to everyone else for all the help aswell.
Appreciate it!
Oldpug
- x 94
Re: Bolt dimensions
As citroJim has said, they are very special calliper only bolts. So why not buy the kits, items 5 or 6 in the link.
- x 2006
Re: Bolt dimensions
https://www.kayfast.co.uk/
For example
https://www.kayfast.co.uk/view-product/ ... -GRADE-109
Bolts fixing etc........
For example
