C5 x7 suspension riding low at the back
Dragondad
Unread post by Dragondad »
Suspension riding low at the non hydrostatic suspension.
I had a broken coil spring I fitted two new coils. Suspension has leveled out between left and right rear wheels. Problem from suspension is higher than the rear. Stand four fingers from top of wheel arch at the front, only two fingers from top of wheel to wheel arch at the rear.
Other than putting new shocks on it the coil goes over the shocks in this design like a mono shock on a motorbike. Any one ideas how to fix this. Other than strut arm extension. Which I just made up and don't know if they exist lol.
PaulC5
x 718
Re: C5 x7 suspension riding low at the back
Unread post by PaulC5 »
The coil springs set the height so no point in changing the shocks. Did you fit coil springs from Citroen or are they pattern parts ? If pattern then possibly they are not the same as the original Citroen ones.
x 6950
I also suspect incorrect parts.
The springs are totally different according to engine type (petrol / diesel), plus engine variant, saloon, estate and other options / equipment, so there are multiple part numbers. So the incorrect part can cause this sort of thing can happen.
If you need the correct versions see below:
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Dragondad
I used a motor factors for the coil spring. So most likely pattern parts.napa. Now thinking of just fitting coil spring assistors to slightly level up the back. It passed an mot. So the people there weren't bothered by it. Annoying if I have fitted wrong parts.they did look the same size has the intact one I removed.
PaulC5
x 718
If it is riding high at the front where I suspect you have put the new springs, then its handling might not be right. The tyres might also start to wear badly. Can you take the springs back and complain ? For it to sit higher and being the same length uncompressed, the springs are probably stronger than the original so not compressing as much. If you still have the originals they may have painted bands on them which identifies them so something to note when getting replacements from Citroen (or used ones).
