C5X Fuse Box
andyc82
C5X Fuse Box
Unread post by andyc82 »
Hi all,
Usually I've been able to find this info online, but does anyone have a fuse box diagram for the C5X? Trying to hard wire my dashcam and can't find the info I need :D
Thanks!
x 6950
Re: C5X Fuse Box
No, unlikely you will as it's such a recent car.
However, first decide if you want a permanent live or switched live.
Then use a piggy back fuse from one in the passenger glovebox and a multimeter to test which fuses remain on after ignition is switched off, However, bear in mind some equipment is on a timer for a set period after the ignition is switched off, like the electric windows, so I suggest you may want to wait for a few minutes after ignition off to test fuse candidates. As long as you use a piggy back fuse with it's own specifically rated fuse as determined for your dash model you should be ok.
Sloppysod
x 407
Re: C5X Fuse Box
Unread post by Sloppysod »
andyc82 wrote: 05 Nov 2024, 12:06 Hi all,
Thanks!
Can you please post outcome so as to help others? 👍
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
