I'm suspecting I have a faulty fuel pressure regulator (DV6TED4 HZ engine)
The actuator test in Diagbox says to touch the regulator and feel it vibrate.
Mine does nothing but I can hear (but not feel) a click on an off while the actuator test is running.
Is this correct or have I actually found the smoking gun?
Fuel pressure regulator 1.6 HDi
freddyokel
- x 6
freddyokel
- x 6
Re: Fuel pressure regulator 1.6 HDi
Update: just run the same test on my partner's DV6D HP engine and I can't hear the vibrate either (I don't actually know where the regulator is on this one). But... it doesn't click...
Mihael_M
- x 36
https://www.ebay.co.uk/itm/254429177549
It looks like this and is located on the high pressure pump.
And the pump looks like this.
https://catalogs.ssg.asia/citroen/?lang ... aWVyPT0%3D
freddyokel
- x 6
Yeah, I've got a spare.
Just wondered if it was actually supposed to vibrate when you ran the test in Diagbox.
If it wasn't such an utter <insert word here> to access I'd have just swapped it out.
Snurbo76
Hello everybody i have a peugeot partner and I may have a problem with the regulator on the pump but how can i remove it i cant see it and not enough space to get down my hands. Sometime my check engine lamp lights up and I get 2 error codes for low rail pressure and onekligen for big leak in the diesel system. I know one injector is leaking more then the other three so maybe it could be that one?
Hope you understand my bad english
Best regards Sven-Anders from sweden
