NS wing mirror indicator DS5
geoffwa3
Unread post by geoffwa3 »
Has anyone attempted swapping out the led indicator strip in the wing mirror?
Mine is damaged and wanted to have a go at replacing if easy enough.
2014 model
Thanks Geoff
x 6960
Re: NS wing mirror indicator DS5
I think you'll first have to remove the mirror, then the motor bolts, the motor, to provide access to the shell clips, remove, then this should give access to the indicator module wiring connector and the unit which should then be able to be swapped out.
geoffwa3
Thanks for the info Marc, apologies for the delayed reply.
skragamuffin
Unread post by skragamuffin »
did you get this done and was it fairly easy
thank you
