Space Tourer Brakes and pads question
Bill1971
Unread post by Bill1971 »
Hello.
I’m living in Germany and require new brake pads and discs for my Space Tourer 2.0 HDI 177 PS(130kW).
Year October 2018.
From the VIN, I have the code 3001/AYN.
Unfortunately, this is not recognized on Bandel or other parts sellers.
Does anyone know if the brake pads and discs are the same for the Jumper 3001/AWN or can offer any help in tracking down the required ones?
On a side note, I’ve pulled a caravan for the last 4 years and the pads have got quite hot at times - probably slightly warped as the usual noise can be heard and vibrations at high speed. Has anyone else had this before?
x 6945
Re: Space Tourer Brakes and pads question
Those are not correct part numbers. It's unlikely that parts from other vehicles are the same - most are different even in a small way.
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
