5008 MK2 Fault codes
Savage87
Unread post by Savage87 »
Hello,
I have a couple of codes that are a bit of a head scrather, don't know what to do with them.
This is on my Peugeot 5008 MKII 1.6BlueHDI 120BHP. VIN VF3**************[VIN obfuscated, can be read by forum staff]
Built-in systems interface BSI2010_EV
B1865 23 Lack of coherence between the status of the engine starting switch and the status of the built-in systems interface internal combustion engine starting authorisation ouptut
U1F00 00 Fault event not stored in the faults log
U1F01 66 Fault: unwanted triggering of the BSI LIN 1
Engine wiring housing BSM_2010
B113D 15 Right-hand dedicated daytime lamp fault Short circuit to positive or open circuit
B113E 15 Left-hand dedicated daytime lamp fault Short circuit to positive or open circuit
I haven't noticed any problems with the lamp, these are intermittent and keep coming back. I'm looking for a common point where I might need to check supply.
Windscreen wiper ESV (Working fine)
B100C 16 Wipers ECU supply low voltage Intermittent
Looking for schematic/location so I can check connectors/wires.
Instrument panel CIROCCO
U1FA0 00 LVDS signal response time incorrect
Touch screen MF_DGT_LVDS_BD
U1FA0 00 LVDS response time incorrect (LVDS : Low Voltage Differential Signalling)
Audio-navigation / connected audio system (ECU not recognised)
B1505 13
U18A1 00
B1506 00
Service module / Independent telematic unit BTA_2
F303 Secure configuration fault
Motorised Boot Unit VERINS_MOTORISES (Working fine)
B1003 55 Configuration fault
Hopefully someone know how to fix the above. Thanks!
x 1489
Re: 5008 MK2 Fault codes
Do you have any issues, or just faults when scanned?
Savage87
No issues, just fault when scanned.
I'm trying to do something about it before it becomes a problem.
x 1489
I would just ignore them. They seem to throw codes up for fun if the battery voltage is not spot on - there were loads in our 2017 C4 when I scanned it.
Wacd
x 3
Unread post by Wacd »
Savage87 wrote: 07 Oct 2024, 18:51 Instrument panel CIROCCO
B1505 13
U18A1 00
B1506 00
Hello sir, i have exact same DTC's , have you been able to find a fix for these?
Savage87
No, I haven't fixed them, but haven't caused any problems either.
Wacd
x 3
Savage87 wrote: 22 May 2025, 01:49 No, I haven't fixed them, but haven't caused any problems either.
Thanks for the update. I'm having some intermittent problems and DTC's popping up every now and then.
I'd truly appreciate if someone can share 508 R8 9693637680 Nac calibration file.
