Hello,
I have a couple of codes that are a bit of a head scrather, don't know what to do with them.
This is on my Peugeot 5008 MKII 1.6BlueHDI 120BHP. VIN VF3**************[VIN obfuscated, can be read by forum staff]
Built-in systems interface BSI2010_EV
B1865 23 Lack of coherence between the status of the engine starting switch and the status of the built-in systems interface internal combustion engine starting authorisation ouptut
U1F00 00 Fault event not stored in the faults log
U1F01 66 Fault: unwanted triggering of the BSI LIN 1
Engine wiring housing BSM_2010
B113D 15 Right-hand dedicated daytime lamp fault Short circuit to positive or open circuit
B113E 15 Left-hand dedicated daytime lamp fault Short circuit to positive or open circuit
I haven't noticed any problems with the lamp, these are intermittent and keep coming back. I'm looking for a common point where I might need to check supply.
Windscreen wiper ESV (Working fine)
B100C 16 Wipers ECU supply low voltage Intermittent
Looking for schematic/location so I can check connectors/wires.
Instrument panel CIROCCO
U1FA0 00 LVDS signal response time incorrect
Touch screen MF_DGT_LVDS_BD
U1FA0 00 LVDS response time incorrect (LVDS : Low Voltage Differential Signalling)
Audio-navigation / connected audio system (ECU not recognised)
B1505 13
U18A1 00
B1506 00
Service module / Independent telematic unit BTA_2
F303 Secure configuration fault
Motorised Boot Unit VERINS_MOTORISES (Working fine)
B1003 55 Configuration fault
Hopefully someone know how to fix the above. Thanks!
5008 MK2 Fault codes
- x 1470
Savage87
Re: 5008 MK2 Fault codes
No issues, just fault when scanned.
I'm trying to do something about it before it becomes a problem.
- x 1470
I would just ignore them. They seem to throw codes up for fun if the battery voltage is not spot on - there were loads in our 2017 C4 when I scanned it.
Wacd
- x 3
Hello sir, i have exact same DTC's , have you been able to find a fix for these?Savage87 wrote: 07 Oct 2024, 18:51 Instrument panel CIROCCO
B1505 13
U18A1 00
B1506 00
Savage87
No, I haven't fixed them, but haven't caused any problems either.
Wacd
- x 3
Thanks for the update. I'm having some intermittent problems and DTC's popping up every now and then.Savage87 wrote: 22 May 2025, 01:49 No, I haven't fixed them, but haven't caused any problems either.
I'd truly appreciate if someone can share 508 R8 9693637680 Nac calibration file.
