Ds3 2011 1.6hdi fault code p1a9c
Beaker
Unread post by Beaker »
My Citroen ds3 2011 fault code P1A9c power Acumulator. . Help needed
x 6950
Re: Ds3 2011 1.6hdi fault code p1a9c
VIN required. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Beaker
x 6950
Here you go, so this means your Stop Start System has an Energy Accumulator and this seems to be on the fritz / end of service life.
Fault Code: P1A9C
Description of Fault:
  • Energy accumulator: Energy accumulator state of health fault. The state of health of the energy accumulator is detected at the low limit for 0,48 s.
Conditions for Fault to clear:
  • Ignition on
Downgrade Modes whilst Fault is active:
  • Switching on of the warning lamp and/or warning message: "SERVICE" warning lamp
Symptoms:
  • Absence of automatic stopping of the internal combustion engine
  • Malfunction of the Stop and Start switch or its LED
Suspect Areas:
  • Terminals of energy accumulator and voltage retaining device
Beaker
I have got 14.4v going into the stop start ecu under the passenger wing but nothing into the power accumulator. Can I just replace the accumulator without programming the stop start ecu?
[Moderator comment: the attached image files seem to be too small.]
x 6950
All these images are blank :dunno:
x 1953
Unread post by Paul-R »
They're all black for me.
Beaker
Tried to post the diagnostic pictures but won’t work.
x 5683
See This Guide to uploading images.
x 6950
@Beaker: Note if you are trying to screenshot the diagnostic screen from a laptop this may be your graphic card memory, especially if it doesn't have a dedicated GPU and shares ram with the laptop.
Best to use the snip tool or another utility to capture a screen if this is the case.
Beaker
Volts at terminal of power 0.5v
Overheating of the voltage retaining device
Voltage retaining device faulty
These are the diagnostic I got .
Changed the power regulator under the arch with a second hand one but no joy.
Beaker
Is there a wiring diagram for the stop start system
Can I replace the stop start capacitor without programming the stop start ecu
