Ds3 2011 1.6hdi fault code p1a9c
Beaker
My Citroen ds3 2011 fault code P1A9c power Acumulator. . Help needed
- x 6954
Re: Ds3 2011 1.6hdi fault code p1a9c
VIN required. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Beaker
- x 6954
Here you go, so this means your Stop Start System has an Energy Accumulator and this seems to be on the fritz / end of service life.
| Fault Code: | P1A9C |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Beaker
I have got 14.4v going into the stop start ecu under the passenger wing but nothing into the power accumulator. Can I just replace the accumulator without programming the stop start ecu?
[Moderator comment: the attached image files seem to be too small.]
- x 6954
All these images are blank
- x 1921
They're all black for me.
Beaker
Tried to post the diagnostic pictures but won’t work.
- x 5650
See This Guide to uploading images.
- x 6954
@Beaker: Note if you are trying to screenshot the diagnostic screen from a laptop this may be your graphic card memory, especially if it doesn't have a dedicated GPU and shares ram with the laptop.
Best to use the snip tool or another utility to capture a screen if this is the case.
Beaker
Volts at terminal of power 0.5v
Overheating of the voltage retaining device
Voltage retaining device faulty
These are the diagnostic I got .
Changed the power regulator under the arch with a second hand one but no joy.
Beaker
Is there a wiring diagram for the stop start system
Can I replace the stop start capacitor without programming the stop start ecu
