service schedule for 2019 k9 berlingo van 1.6 diesel
john79
Unread post by john79 »
Hi does anyone have a service schedule for the above van please :-D
thanks
john.
x 6956
Re: service schedule for 2019 k9 berlingo van 1.6 diesel
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
john79
Hi thanks for the reply, i have now made a donation , my vin is VR7**************[VIN obfuscated, can be read by forum staff] if you could find out the service schedule and also a build sheet for this van i would be greatfull
cheers john.
x 6956
Thanks for your Forum Donation John, info as requested:
Main Servicing Info
Click Image to Zoom
Vehicle Build Sheet
Vehicle Characteristics
Vehicle familyBERLINGO VU (K9)
AS/RP N°15499 FV 2 1055
Warranty Start Date17/07/2019
Engine Serial number10 JCAV 0088477
OPB00F9
BERe2*2007/46*0625*04
P4A9824641799
General Information
PRODUCT TYPECOMMERCIAL VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYBERLINGO VU (K9)
SILHOUETTESHORT WHEELBASE VAN H1 6
TRIM LEVELCOMMERCIAL VEHICLE LEVEL 2 PSA
ENGINEDV6FE FAP DIESEL
TRANSMISSIONBVM5
PAINT TYPENON-METALLIC PAINT
BODY COLOUREWP - BANQUISE WHITE PAINT
INTERIOR TRIM TYPEWW CURIT TRI + WW BRAZ "OA"
UPHOLSTERY COLOUR"FY"
GEARBOX (CHARACTERISTICS)MANUAL GEARBOX BE4/5 O
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)DV TYPE ENGINE
PRE-EQUIPMENT FOR CONVERSIONWITHOUT PRE-EQUIPMENT FOR CONVERSION
Fuel Supply-Engine
FAN1 X 2-SPEED FAN 95W AERO DYNAMIC FLAP
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAPFUEL TANK CAP WITH LOCK
DIESEL FILTER WATER DETECTORWITH DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.1 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
FUEL TANKFUEL TANK WITH LOCATING TAB
COOLING MOTORRADIATOR 28DM2
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)55KW - 233NM
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPEGEARBOX BE4R
TRANSMISSIONBVM5
FINAL DRIVE RATIOAXLE RATIO 17 X 73
WHEEL STYLEBLACK 15-INCH STEEL WHEEL
CLUTCHHYDRAULIC CLUTCH
RIM/TYRE SIZE15 INCH TYRE FITMENT
TYRE (SIZE, TYPE)TYRE 195/65 R15 91H
WHEEL (TYPE)STEEL WHEELS
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANTESP BOSCH 9.1
STEERING (OPERATION)LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
REAR ANTI-ROLL BARRR ANTI-ROLL BAR STIFFNESS 39000 NM/RAD
ANTI-THEFT DEVICEANTI-THEFT USING MECHANICAL ANTI-THEFT DEVICE
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 37500 NM/RAD
STEERING WHEEL ANGLEWITH ABSOLUTE STEERING WHEEL ANGLE ESTIMATOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
Body Fittings
HANDS FREE ACCESS AND STARTINGWITHOUT HANDS-FREE ACCESS/STARTING
TOWBARWITHOUT TOWBAR
AERIALSHORT ROOF AERIAL
CABINWITHOUT CAB
PAYLOADPAYLOAD 650 KG
FINISHER (SELF-ADHESIVE)WITHOUT GLASS ADHESIVE TAPE
REAR SPOILERWITHOUT REAR AERODYNAMIC SPOILER
DECORATION (PAINTED)WITHOUT PAINT DECORATION
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
WHEEL EMBELLISHER (STYLE)15 INCH SAULIRE WHEEL TRIM
UNDERBODY SHIELDWITHOUT PROTECTION UNDER BODY
INDICATORSWITHOUT SIGNALING LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR
SPLASH SHIELDSTANDARD MUD GUARD
ENGINE BAY SOUNDPROOFINGUNDERBONNET + BULKHEAD SOUNDPROOFING
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER2-SPEED INTERMITTENT WIPER + ADJUSTMENT
REAR SCREEN WIPERW/O REAR SCREEN WASH WIPE
REAR ROOF FLAPW/O ROOF TRAP
REAR TAILGATE GLASSWITHOUT TAILGATE WINDOW
SIDE LOAD DOORSLIDING LH SIDE DOOR
BUMPERNEUTRAL/BODY COLOUR STD FR BUMPER-NEUTRAL STD RR
LUGGAGE RACKLUGGAGE-CARRIER PRE-EQUIPMENT
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
SPARE WHEELSTANDARD SPARE WHEEL
EXTERIOR ACCESSORIESEXT OPENING CONTROL+NEUTRAL MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
BUMPER TRIMBUMPER WITHOUT TRIM
REAR WINDOW (TYPE)WITHOUT REAR WINDOW
GLASS (APPEARANCE)WINDOW TINTED
WINDOW (TYPE)LAMINATED WINDSCREEN
SIDE WINDOW (COMM. VEH. ONLY)WITHOUT SIDE WINDOW
ROW 3 SIDE WINDOWMETAL WINDOWS 3ND ROW
Interior Fittings
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
SIDE ARMREST (TYPE)FR SIDE ARMREST+PULLING HANDLE INJECTED GRAINED
ANTI-THEFT ALARMVOLUME+PERIMETER+LIFTING ALARM
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
REAR SEATWITHOUT REAR SEAT POSITION
SUPPLEMENTARY SEATWITHOUT ADDITIONAL SEAT
BLIND SPOT DETECTIONWITHOUT BLIND SPOT MONITORING
CABIN SEATADJUSTABLE BENCH SEAT
INT. LOAD RETENTION6 LASHING RINGS
LUGGAGE COVERWITHOUT LUGGAGE COVER
REAR SEATBELTWITHOUT REAR SAFETY BELT
FRONT SEATBELT3 INERTIA REEL 2 SIDE PRET FR SEAT BELT DRIVER+PASS
ASHTRAYWITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX
CHILD LOCKWITHOUT CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GRAB HANDLESWITHOUT HANDLES
CONSOLELOWER CONSOLE
DRIVING POSITIONRIGHT HAND DRIVE
REMOTE CONTROLINSTALLATION OF BOOT REMOTE CONTROL
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
BOOT AND LOAD SPACE LIGHTINGAUTO BOOT LIGHT OR LOAD VOL SWITCH
MISC. INT. LAMPSFRONT SPOTLAMP
WORK TABLEWITHOUT WORK TABLE
LOAD SPACE TRIMPVC BOOT CARPET
UNDERSEAT STORAGE1 UNDER SEAT STORAGE DRAWER
INSTRUMENT PANEL (CHARACTERISTICS)LCD INSTRUMENT PANEL + TEXT
CHILD SEAT ANCHORING POINTSCHILD SEATS WITH ISOFIX ANCHORAGES
LOUDSPEAKERMOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS
RADIO CONTROLSSTEERING WHEEL AUDIO SYSTEM CONTROL
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
PASSENGER COMPARTMENT SOUNDPROOFINGBULKHEAD SOUNDPROOFING
FRONT PASSENGER SEAT CONTROLMANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT PASSENGER SEAT FOLDINGWITH STANDARD FOLDING FR PASSENGER SEAT
INT. UPHOLSTERY ELEMENTSWITHOUT INTERIOR TRIM COMPONENTS
COMPACT DISCWITHOUT COMPACT DISC
STOWAGE BINWITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFTWITHOUT REAR GLASS LIFT
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
CABIN CARPETR1 TPO
DRIVER’S WINDOW LIFTSEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYDGT8C SCREEN DISPLAY
MISC. INT. ACCESSORYDOCUMENT HOLDER TABLE
COURTESY MIRRORDRIVER’S MIRROR CONCEALING FLAP WITH LIGHTING
CUSHION PADDINGPADDING WITHOUT PASSENGER DETECTION PAD
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGWITHOUT FRONT SIDE AIRBAG
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
PASSENGER AIRBAGNO PASSENGER AIRBAG
EQUIPMENT PACKW/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATIONWITHOUT AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)NEUTRAL FINISH INSIDE DOOR HANDLE
REAR MOVING PANEL2 REAR HINGED METAL DOORS
FRONT SEAT GUARDNOT REMOVABLE PANEL
WIFIWITHOUT WIFI
STORAGE (DRIVING POSITION)OPEN LOWER STORAGE COMPARTMENT+ENCLOSED UPPER STORAGE COMPARTMENT
RADIO RECEIVERDIGITAL CONNECTED COLOUR RADIO
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLPARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORWITHOUT INTERIOR MIRROR
STORAGE (OTHERS)W/O OTHER SETTING BOXES
CARPET COVERW/O CARPETMAT
OBSTACLE DETECTION SYSTEMREAR RADAR OBSTACLE SENSOR
LATERAL BLINDSWITHOUT SIDE BLINDS
TRIM ADAPTATIONHEART OF THE RANGE GEAR LEVER KNOB+PVC GAITER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEAD LOCKING
STEERING WHEELSTANDARD STEERING WHEEL
Electrical
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
ALTERNATORALTERNATOR 150 AMP
BATTERYBATTERY L2 640 60AH EF 640 EN
STARTER MOTORSTARTER MOTOR CL 4
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEAR"00" MINOR INDEX
CONDENSER (SPECIFICATIONS)CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETWITHOUT ACCESSORY SOCKET
SIDE IMPACTSREINFORCED SIDE IMPACT PROTECTORS
SET OF KEYS2 HIGH FREQUENCY REMOTE CONTROL KEYS
DOOR SEALWITHOUT SEAL DIRT EXCLUDER
COUNTRY ADAPTATIONWITHOUT ADAPTATION COUNTRY
REFRIGERANTREFRIGERANT LIQUID R134
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
john79
wow that was quick thankyou
x 6956
No worries, we don't like to hang about here! (well on a good day). :-D
