DPF and SCR on a 3008 1.5 Diesel
Eitan2006
Unread post by Eitan2006 »
Hi Experts,
Two short technical questions regarding 3008 1.5 Diesel - 2019, please....
1. Does DPF module come before SCR in the exhaust pipeline ?
2. Are DPF and SCR two physically separated modules ? (Can I replace one and not the other ?)
Thanks !!!!
x 6957
Re: DPF and SCR on a 3008 1.5 Diesel
1) The DPF is the last part in the combined unit, after the catalytic converter and captures the particulate matter.
2) The Selective Catalytic Reduction is a process, not a module. A UREA solution (Adblue) is sprayed into the catalytic converter where it converts the NOx gases into water and
Nitrogen.
As to whether you can replace them separately will depend on your vehicle. Some units are a complete unit others allow them to be separated. You'll need to provide your VIN so I can see which type you have.
Eitan2006
GiveMeABreak wrote: 16 Sep 2024, 19:07 1) The DPF is the last part in the combined unit, after the catalytic converter and captures the particulate matter.
Nitrogen.
Thanks for the answer
Where can I find a diagram of Peugeot 3008 1.5 Diesel exhaust system ?
Thanks !
x 6957
Please refer to my last post first. I’ll need your VIN to see which you have.
If you require parts or part diagrams, this will require a membership upgrade as this is a chargeable service:
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Eitan2006
Thank you very much !
My VIN is W0VZCYHZ2KS307229
It is an Opel Grandland X. I assumed it is mechanically the same as Peugeot 3008. Now I understand it is more complicated...
Can you please still check it ?
Anyway - Thank you very much for the response !!!
x 6957
Sorry, we only deal with PSA vehicles, (Citroen, DS & Peugeot). I thought we were talking about your 3008. I can't help you with Vauxhall because they have a different VIN and we don't support them here.
Eitan2006
GiveMeABreak wrote: 18 Sep 2024, 10:04 Sorry, we only deal with PSA vehicles, (Citroen, DS & Peugeot). I thought we were talking about your 3008. I can't help you with Vauxhall because they have a different VIN and we don't support them here.
hi,
...but Opel cars are manufactured by PSA, and Grandland is supposed to be based (mechanically) on 3008.
Thanks !
x 6957
Yes, I am fully aware of that, but please read my post above - we do not support Vauxhall as they use a different VIN for which we do not subscribe to their systems, so cannot provide you with any data. This is a French Car Forum, not a Stellantis Car Forum - we only support PSA vehicles.
Eitan2006
OK. Thanks !
x 6957
