2015 C4 grand picasso dpf additive level low warning
Psmk222
Unread post by Psmk222 »
I got this message on the dash and have refilled the additive tank. When I took it to the garage to have the system reset the diagnostics machine says there's a fault with the additive pump but im still getting the additive level to low warning on the dash....is the pump easy to replace and if I replace it will that clear the errors or do I still need to have the diagnostics done.
Psmk222
Re: 2015 C4 grand picasso dpf additive level low warning
I am going to replace the whole additive tank and refill ... will this clear the error or do I still need diagnostics
x 6950
Yes you will need to initialise the additive pump - especially if it is a multiplexed pump. Usually this can be informing it via replacement parts that it has been replaced and then undertaking the priming functions for example.
Psmk222
Thanks... do you know if it can be done using carly?
