Ds 4 2010 audio denon does not work
AsH7
Unread post by AsH7 »
Hi guys , i am new here and i have a problem with my citroen ds4 denon audio system.
So i've been to many oficial citroen workshops and alot of services , nobody knows how to repair my Citroen speakers .
I've been send the cd unit to a test and works perfectly , ive been replacing the amplifier with an original aftermarket one and still doest work .
I've been reading that if one speaker doest work the entire unit will not turn on , so i need to check every speaker resistance . Lets say that i'll find one speaker that doest work and need replacing , do i really need an original one ? I cant use and aftermarket one with same specs ?
Also ive been reading that for some reason i cant use an aftermarket amplifier , is that right ?
If does help ill post a picture with the car radio
x 6956
Re: Ds 4 2010 audio denon does not work
You best provide your VIN so I can see exactly what you have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
AsH7
GiveMeABreak wrote: 11 Sep 2024, 14:48 You best provide your VIN so I can see exactly what you have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
x 6956
Incidentally, your vehicle has an outstanding After-sales campaign outstanding from October 2024: The Airbag needs replacing, so book it in at a dealer to get this done. The work will be free. Quote reference JGU.
JGU - C3 (A51), DS3, C4, DS4, DS5 - Airbag
Replace airbag module according to following rework instruction.
JGU
05/12/2023
Ok so RT6 system with Hi Fi Amp. This is a CAN amplifier, so is intended to work with the CAN data network of the vehicle. An aftermarket system may not interface with the RT6.
The system takes the 2 audio outputs from the RT6 and splits these into 8 amplified outputs with the HiFi option:
2 outputs for the front woofers
2 outputs for the front tweeters
2 for the rear tweeters and woofers connected in parallel
2 outputs for the bass acoustic enclosure
You may want to look at the connections:
'a' 16-way black connector
Channel numberDesignation of the connector channels
1Channel not connected
2CAN +
3Channel not connected
4Audio amplifier front right output positive control
5Audio amplifier front right output negative control
6Channel not connected
7CAN INFO DIV High
8Channel not connected
9Central power switch positive
10Channel not connected
11Audio amplifier front left output negative control
12Audio amplifier front left output positive control
13Channel not connected
14CAN INFO DIV Low
15Channel not connected
16Earth
'a' 16-way Bonnet Locking Connector
1Positive control of the front left tweeter
2Positive control of the front left woofer
4Positive control of the rear left boomer and tweeter
6Rear left bass acoustic enclosure positive control
7Channel not connected
9Negative control of the front left tweeter
10Negative control of the front left woofer
11Channel not connected
12Negative control of the rear left boomer and tweeter
14Rear left bass acoustic enclosure negative control
16Channel not connected
'c' 16-way Blue Connector
1Positive control of the front right tweeter
2Positive control of the front right woofer
4Positive control of the rear right boomer and tweeter
6Rear right bass acoustic enclosure positive control
9Negative control of the front right tweeter
10Negative control of the front right woofer
12Negative control of the rear right boomer and tweeter
14Rear right bass acoustic enclosure negative control
AsH7
Ok , ill check them in a couple days and ill comeback with the results , thanks alot
Reason: Please don't quote previous post - not needed.
x 6956
No problem, may give you some pointers for checking the connections.
AsH7
GiveMeABreak wrote: 11 Sep 2024, 23:11 No problem, may give you some pointers for checking the connections.
ok so i am coming with a little update , long story short , the amplifier connection looks like this lmao , there is 2 speakers connected for radio , i dont know what to do now
x 6956
Err.... not surprising it's not working to be honest....
When you say this, surely you would have connected the replacement amp up correctly when you replaced it? I'm confused.
AsH7
GiveMeABreak wrote: 13 Sep 2024, 16:35 Err.... not surprising it's not working to be honest....
so long story , is my brother car and he after being to 100 services , he manage to connect two wires and somehow works only 2 front speakers :rofl2: , as with all speakers connected the amp will not work at all, ill comeback after i figure out what the actually hell is there :lol:
Maniac
Unread post by Maniac »
My problem is diffrent.
Ale speakers ar? ok exept subwoofer.
Resistence is ok but it plays very very quietly. you have to apply your ear to hear it.
Mihael_M
x 34
Unread post by Mihael_M »
If one of the speakers is not good, then it is possible that all the outputs are blocked. To begin with, you can disconnect the connectors b and c. Then all the control signals and only the front speakers are connected. If even then it does not work, it is possible that the front speakers are bad . In that case I would return the b or c connector and disconnect the front speakers at the connectors on them .This applies if only one speaker is faulty. And of course this applies to the original radio . Speakers can be checked and the resistance can be measured with a unimeter. The resistance must be around 4 ohms. If it is below 1 ohm then it is not good . Speakers can be replaced with aftermarket ones, but you need to choose the right size and specification. The connectors generally do not fit, so they have to be modified.
Maniac
When I listen to music, all the door speakers seem to be playing. but when I disconnected b and c there is silence.
Mihael_M
x 34
maniac: then your speakers are fine except for the subwoofer
Djandree
x 38
Unread post by Djandree »
Hi. It should be an option in diagbox to check all speakers. you have to choose amplifier and the repair and you should have a test option. Sending a test tone to all speakers incl sub. Had this in my pug 308cc with jbl amp system
gregy115
Unread post by gregy115 »
Hello guys, I am from Slovenia, have the same problem on my DS4 2014, it has a denon sound system with the woofer integrated, i changed the original radio because has a malfunction in the system and it was too expensive to change it with the new one, so i bought the android version for this car with carplay canbus box integrated, all works rine for 6 months and than suddenly my wife drove soke stuff from Ikea 🤦🏼.. and the sound stop working. I checked the outputs on the radio and they work fine, the problem is the sound in the car, should I check the connection in the woofer? Or what , I am confused
