OK. So code is definitely 0952 which means nothing but here is the description:-
Telematics 1 problems exist
1.0952 FM2 Aerial Fault. No Signal
Now! When I looked at it yesterday, perhaps on a different system, it said FM2 Aerial Fault. Short circuit to open. Earth.
which is a subtle difference.
Can you search on descriptions or Telematics codes?
On a C4 forum, I’ve seen mention of B952 FM2 Aerial.
In case this is inportant, I think the head unit is on 2.77?
Peugeot 3008 FM2 Aerial
- x 6950
Re: Peugeot 3008 FM2 Aerial
Ok, so there is one for this fault. Unless using Diagbox, expect missing parts of codes.
Note the FM2 antenna is screen printed onto the rear screen. There are 2 aerial harnesses from the rear of the RT6. One is for the GPS, FM1 and goes to the aerial base. The other is for FM2 that goes to an adaptor at the rear tailgate and then to the rear screen.
| Fault Code: | B952 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
Rhothgar
- (Donor 2026)
- x 222
Amazing! Thank you Marc. I have seen a diagram somewhere on the group I believe. I’ll have another search for it.
Was reading up about the internal microSD last night too so I wonder if that is worth dealing with at the same time.
For the record, the radio does work.
- x 6950
Then leave it well alone Roger, but, as a precaution, I would take a backup of the user data files whilst it is working, as in future you may need these if it does start to play up and this can help restore the settings if the unit goes toes up and you have no access to be able to back them up at that stage.
You should follow only part 'A' of this guide to back the settings up:
How to Replace the Internal MicroSD Card - RT6
Be aware that as you have the Panoramic Roof, getting to the rear aerial assembly is quite involved and requires removal of the rear crossmember (Blind Sub-Assembly) before you can get to the connections.
