Can anyone advise me what this 30A fuse feeds please?
Engine bay fuse box on 1.6HDi DVC6.
I’d have thought it should have a nut on it but looks like it has never had one!
Will test it for potential issue but curious as there are some outstanding faults in the ECU which I am working through and the resolution of one could be VERY expensive.
3008 Fuse - Identification and potential issue
Rhothgar
- (Donor 2026)
- x 221
- x 1487
Re: 3008 Fuse - Identification and potential issue
There's no cable so I doubt it is in use. It might be the pump supply if an EGS box is fitted.
Rhothgar
- (Donor 2026)
- x 221
Thanks.RichardW wrote: 07 Sep 2024, 15:17 There's no cable so I doubt it is in use. It might be the pump supply if an EGS box is fitted.
Humour me! What is an EGS box? Electronic gearbox system?
- x 1487
Just checked mine, it is the same as yours. Yes EGS is the semi auto robotised manual they used.
