C4GP fan blower problems - please help
Elts
Unread post by Elts »
Hello folks,
The wife’s C4GP (2016) has a problem where the screen demist blower doesn’t blow. This issue started off as intermittent, but is now full time. I’ve tried swapping out the relays behind the glovebox, and a small 3 relay pack located behind the blower chambers, but the fault is still apparent.
Can someone provide the schematics / wiring diagrams please so I can try and properly fault find?
The aircon has recently been fixed bu our local garage. The Anniss’s predates the aircon fix (this was due to a leaking pipe).
Happy to take any advice / pointers as I want it fixed before the cooler weather sets in again.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Based in Aberdeenshire, Scotland.
PaulC5
x 693
Re: C4GP fan blower problems - please help
Unread post by PaulC5 »
When the blower on our Cactus stopped working it needed a new blower resistor pack.
Elts
I have read about the resistor pack failing, but can’t seem to physically locate it.
x 6945
See my post here: viewtopic.php?p=614598#p614598 Item (3) on the diagram, and below (2) in location:
Elts
Time for an update.
I replaced the resistor pack today, and the fault has changed, so I assume multiple faults. Brilliant.
Current status: with the car ignition on (engine off) I have full manual control of the blowers, until I switch the delist on when it runs for a split second then cuts off. When I deselect the screen blower it starts blowing again and I get control back of the fan.
If I start the engine the blowers do not operate.
Please, if anyone has access to the schematics or advice, let me know!
x 6945
Here's a schematic:
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Elts
Thanks Marc. I can figure out the interconnect diagram above, and some of the components (bb00 battery, psf1 is under bonnet fuse box, bsi1 is the bsi behind glove box), but how do I identify and then find the other areas?
I understand that all of the 80’s are linked to the heating/venting/aircon system, but that doesn’t really help.
I need to find where the power to the fans when the engine is running is different from ignition power only.
x 6945
It's a digital system, and internal details off the units are not available, but I have the Pin Info:
The air blower control module control signal is a digital signal of the opening cyclic ratio type.
The value of the cyclic ratio of the control signal defines the power demanded by the driver or front passenger.
"a": 2 way connector
Channel No.Allocation of channels of connector
3Earth
4Battery +
"b": 2 way connector
1Air blower value
2Diagnosis
"c": 2 way connector
5Engine control -
6Engine control +
The only other thing I can think of is the actual Air Conditioning Control ECU itself, which is set back further against the evaporator unit as you can see at (3):
This unit controls everything from the stepper motors to the air distribution etc. and of course commands the Control module for the blower motor.
"a" 40-way blue connector
1A2 phase signal : Mixing stepper motor (right side)
2B2 phase signal : Mixing stepper motor (right side)
3A1 phase signal : Air intake stepper motor
4B1 phase signal : Air intake stepper motor
5A2 phase signal : Air intake stepper motor
6B2 phase signal : Air intake stepper motor
7Sunshine sensor signal
8Sunshine sensor earth
9Signal from the evaporator temperature sensor
10Earth of the evaporator temperature sensor
11B1 phase signal : Mixing stepper motor (right side)
12A1 phase signal : Mixing stepper motor (right side)
13Channel not connected
14Channel not connected
15Channel not connected
16Channel not connected
17Channel not connected
18Channel not connected
19Channel not connected
20Air blower value
21A2 phase signal : Distribution stepper motor
22B2 phase signal : Distribution stepper motor
23Air blower diagnostic link
24Channel not connected
25Channel not connected
26Channel not connected
27Supply of the distribution stepper motor
28Supply of the air intake stepper motor
29Supply of the mixer stepper motor (right side)
30Supply of the mixer stepper motor (left side)
31B1 phase signal : Distribution stepper motor
32A1 phase signal : Distribution stepper motor
33B2 phase signal : Mixing stepper motor (left side)
34A2 phase signal : Mixing stepper motor (left side)
35B1 phase signal : Mixing stepper motor (left side)
36A1 phase signal : Mixing stepper motor (left side)
37Channel not connected
38Channel not connected
39Channel not connected
40LIN
"b" 6-way black connector
Channel numberAllocation of channels of connector
1Earth
2Channel not connected
3ECU 12 V +ve supply
4Comfort CAN High
5Comfort CAN Low
6LIN
Elts
Thanks Marc,
I’ll take a look at the power coming in to the 2 way connector ‘c’, as that sounds like it might be the power for fans at engine running stage.
Elts
So in a bizarre turn of events, after measuring the voltages on the resistor connectors (12v when ignition only, 14+ with engine running) the fault has again changed slightly. Still no blower setting available (but can turn the fan up and down) in ignition only, but occasionally on engine start the fan will work for a few seconds then all switch off. The rear fans work unless the screen blower is selected, then everything cuts off.
Elts
Update - I have now changed out the item 3 (is this the unit marked 8080?) for a 'preloved' unit, and still have the same issues.
In ignition (engine off) I can control the fans, apart from the blower setting which turns all fans off. With he engine running I. can usually (but not always) control the fans, but again when blower selected everything shuts off.
From the diagram above I suspect that something in the PSF1, BSI or another unit has failed and either isn't supplying a signal path (or earth return) for the command from the blower/demister selector.
There doesn't appear to be anyone with a newer diagnostics tool near me (NE Scotland), so it seems like my next logical step is find a trusted autoelectrical garage...
unless anyone else has any input / advice?
I can't find relays 6 & 16 (PSF1) - can anyone point me in their direction?
x 6945
Engine Fuse box relays are internal to the fuse box - they are not intended to be user serviceable components.
