508 SW GT engine cutout on accelerating. Injector replace.
deemax_real
Unread post by deemax_real »
Hi, my car starts cutting out on uphill acceleration with P0087 and P0094 errors. After fuel return tests 1st injector from the gearbox side shows a LOT of fuel on return (about 20x more than other 3). I've taken it off and sent for repair but been told that the coil is damaged and I need new/reconditioned one. Bought 1 but now searching for service manual about the torque when installing the new one. I've found 1 manual for DW12C injectors on Citroen subforum but don't have acces :(
If anyone can help will be great.
x 6946
Re: 508 SW GT engine cutout on accelerating. Injector replace.
That section requires a membership upgrade - see below:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
deemax_real
Hi, Donate done :)
deemax_real
x 6946
Hi, thanks for your Forum donation, just give me a little while to sort something out, as I've noticed the procedure needs modifying to fit the contents correctly. Check back here in about 30 mins. to allow me enough time to correct it.
x 6946
Ok, so all corrected, you hve automatic access to the area, but here's the guide:
C5 X7 DW12C Injector Removal / Refitting
