Citroen C4 VTS EW10J4S wiring diagram
airwave
Unread post by airwave »
Hello, I have '04 C4 Coupe with EW10J4S, and looking for wiring diagram. Sorry if there is another similar thread. I bought car build as rally car, so now there is some issues with wiring, as previous owner tried to do upgrades/remove unused for rallying wirings (fog lights, parking sensors, etc. ) now high beams don't work - xenons was changed to normal lamps, and so on. Anyone have wiring diagram for those things, excluding main wirings like engine or something like that ant willing to share it?
x 1055
Re: Citroen C4 VTS EW10J4S wiring diagram
Unread post by wheeler »
The wiring diagrams are separate diagrams for each system. if you are looking for diagrams for several different systems your best bet is probably to get a copy of Servicebox/SEDRE. This is a backup copy of what the dealers use up to 2014 so sould be perfect for you, you can then access al the diagrams you need.
Something like this> https://www.ebay.co.uk/itm/315382445713 ... R67z5_ixZA
airwave
Thanks, I'll try to do that ;)
