Citroen C4 VTS EW10J4S wiring diagram
airwave
Hello, I have '04 C4 Coupe with EW10J4S, and looking for wiring diagram. Sorry if there is another similar thread. I bought car build as rally car, so now there is some issues with wiring, as previous owner tried to do upgrades/remove unused for rallying wirings (fog lights, parking sensors, etc. ) now high beams don't work - xenons was changed to normal lamps, and so on. Anyone have wiring diagram for those things, excluding main wirings like engine or something like that ant willing to share it?
- x 1056
Re: Citroen C4 VTS EW10J4S wiring diagram
The wiring diagrams are separate diagrams for each system. if you are looking for diagrams for several different systems your best bet is probably to get a copy of Servicebox/SEDRE. This is a backup copy of what the dealers use up to 2014 so sould be perfect for you, you can then access al the diagrams you need.
Something like this> https://www.ebay.co.uk/itm/315382445713 ... R67z5_ixZA
airwave
Thanks, I'll try to do that
