VIN Help
almirjaha
VIN Help
Unread post by almirjaha »
Hello
Can someone help me, I should compare these two cars:
x 6946
Re: VIN Help
One's a diesel and one's a petrol. What is it you want to compare?
almirjaha
Re: VIN Help
Both are diesels.
x 6946
Re: VIN Help
Oops, copied the VIN incorrectly - had another vehicle on the clipboard.
Both diesels, yes, but one is a 1.6 DV6 HDi and the other a Blue HDI 1.5 DV5.
If you want build sheets showing the standard factory equipment fitted, then you'll need to upgrade your membership. See below:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
almirjaha
Re: VIN Help
Thanks. I made the payment.
I am interested in everything I can find out about the vehicle
C3 AirCross.
x 6946
Re: VIN Help
Initial observations:
The 1.5 has a later Euro 6.2 classification, has slightly more power, has Digital connected Radio, diodes in the mirror, 6 speed gearbox, automatic air conditioning, front fog lamps (cornering function) and rear parking assistance.
The 1.6 is a 5 speed, Euro 6.1, simple A/C, no fog lamps, analogue radio, no mirror diodes, no parking assistance.
Here's the one for VIN ending 866, which is the older 1.6 version:
Vehicle Characteristics
Vehicle familyC3 AIRCROSS (A88)
AS/RP N°15191 VB 1 2357
Warranty Start Date28/06/2018
Engine serial number10 JBHT 3126634
OPB00B8
BERe4*2007/46*1241*01
P4A9693229580
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC3 AIRCROSS (A88)
SILHOUETTEFAMILY SALOON
TRIM LEVELMEDIUM MEDIUM
ENGINEDV6FD FAP DIESEL
TRANSMISSIONBVM5
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOURKHJ - BLUE REEF PAINT
INTERIOR TRIM TYPEHALF LEATHER B71 "4Y"
UPHOLSTERY COLOUR"FT"
GEARBOX (CHARACTERISTICS)MANUAL GEARBOX BE4/5 O
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)DV TYPE ENGINE
ROOF (EXT. ASPECT)BODY COLOUR ROOF
OTHER BADGEWITHOUT FULLER BADGE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEFAMILY BADGE
SPEEDOMETER DRIVEWITHOUT SPEEDOMETER RATIO
Fuel Supply-Engine
FAN1 AERO 2-SPEED 140W FAN WITH SCOOP
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
TANK FILTERCITHOUT RESERVOIR FILTER
STOP AND STARTWITHOUT STOP AND START
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.1 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
REAR IMPACTSSTANDARD RR BUMPER
FUEL TANKNON-PRESSURISED FUEL TANK WITH LOCATING TAB
COOLING MOTORRADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)POWER 73 KW - 254 NM
VALVE PER CYLINDER2
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPEGEARBOX BE4R
TRANSMISSIONBVM5
FINAL DRIVE RATIOAXLE RATIO 19 X 72
WHEEL STYLESTYLE 16 INCH STEEL WHEEL
CLUTCHHYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX)84 DIAMETER DIFFERENTIAL
RIM/TYRE SIZE16 INCH TYRE FITMENT
TYRE (SIZE, TYPE)205/60 R16 92H NON REINFORCED TYRE
WHEELS FITTED6,5" RIM ROAD WHEELS
WHEEL (TYPE)MOUNTING OPTIMIZED STEEL WHEEL
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANTBOSCH 9.0 ESP
ABSWITH ABS BRAKES
REAR ANTI-ROLL BARWITHOUT REAR ANTI-ROLL BAR
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 22
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH ABSOLUTE STEERING WHEEL ANGLE ESTIMATOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
Body Fittings
HANDS FREE ACCESS AND STARTINGWITHOUT HANDS-FREE ACCESS/STARTING
TOWBARWITHOUT TOWBAR
AERIALAERIAL + GPS + GSM
OPENING ROOF (APPEARANCE)WITHOUT SUN ROOF
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE)WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE)16 INCH BABYLON STYLE WHEEL TRIM
EXHAUST TAILPIPESINGLE EXHAUST OUTLET
UNDERBODY SHIELDWITHOUT PROTECTION UNDER BODY
REVERSING LAMPSWITH 1 REVERSING LIGHT
INDICATORSLUMINOUS SIGNATURE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
WASHER JETSTANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTIONMANUAL FOLD EXTERIOR MIRROR
ENGINE BAY SOUNDPROOFINGUNDERBONNET + BULKHEAD SOUNDPROOFING
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER2-SPEED INTERMITTENT WIPER + ADJUSTMENT
REAR SCREEN WIPER (OPERATION)AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERBUMPERS FR/RR DUAL-TONE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC)SINGLE OPTIC LAMPS
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)ELECTRIC DRIVER’S EXTERIOR MIRROR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESBODY COLOUR EXTERIOR HANDLE
SPARE WHEEL MOUNTINGSTANDARD SPARE-WHEEL CARRIER
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
SUN ROOFWITHOUT SUN ROOF
BUMPER TRIMBUMPER TRIM PAINTED FAIRING
GLASS (APPEARANCE)WINDOW TINTED
WINDOW (TYPE)LAMINATED WINDSCREEN + TOUGHENED REAR SCREEN
Interior Fittings
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET1 USB SOCKET
TELEMATIC UNITWITHOUT TELEMATIC UNIT
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTFRONT HEADREST ADJUSTABLE
REAR SEATSEPARATE FOLD BACK BENCH SEAT
BLIND SPOT DETECTIONWITHOUT BLIND SPOT MONITORING
LUGGAGE COVERSHELF
REAR SEATBELTPYRO LAT RR SEAT BELT RETRACTOR + 3 POINT BELT
FRONT SEATBELTRETRACTOR ALARM DRIVER + PASS S/BELT
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
AIR CONDITIONINGAIRCON WITH MANUAL AIR INLET
CHILD LOCKMANUAL REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GRAB HANDLESPASS FR HANDLE + REAR + HOOK
DRIVING POSITIONLEFT-HAND DRIVE
REMOTE CONTROLWITH REMOTE CONTROL
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGWITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTINGLOAD VOLUME + BOOT LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENTGLOSS GREY DECOR
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD HANDBRAKE KNOB
MISC. INT. LAMPSWITH MAP READING LAMP
LOAD SPACE TRIMBOOT CARPET MAT
UNDERSEAT STORAGEWITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS)LCD+TEXT+CHROME SURROUND INSTRUMENT PANEL
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
RADIO CONTROLSSTEERING WHEEL AUDIO SYSTEM CONTROL
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
PASSENGER COMPARTMENT SOUNDPROOFINGW/O CAB SOUND-PROOFING
FRONT PASSENGER SEAT HEIGHT CONTROLWITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLMANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT FOLDINGWITH STANDARD FOLDING FR PASSENGER SEAT
FRONT SEAT ARMRESTASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTMANUAL CONTROL REAR WINDOW
TRAFFIC INFORMATION READERWITH LATERAL TRAJECTORY MONITORING
CABIN CARPETFR+RR PASSENGER COMPARTMENT MATS
DRIVER’S WINDOW LIFTSTANDARD ELECTRIC DRIVER’S FR WINDOW
PASSENGER’S WINDOW LIFTSTD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW
DISPLAYDIGITAL TOUCH SCREEN
CUSHION PADDINGPADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGWITHOUT DOOR SILL LIGHTING
PASSENGER AIRBAGWITH AIRBAG ON PASSENGER SIDE
ON-BOARD COMPUTERCOMPUTER
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)CHROME FINISH INSIDE DOOR HANDLE
COURTESY LAMPFR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SUN VISORDRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
WIFIWITH WIFI
STORAGE (DRIVING POSITION)LOWER ODDMENTS TRAY WITH FLAP
RADIO RECEIVERANALOGUE CONNECTED COLOUR RADIO
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLDRIVER’S SEAT HEIGHT MANUAL ADJ
INTERIOR REAR VIEW MIRRORDAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATIONWITHOUT REGULATION AIRCON/TEMP
STORAGE (OTHERS)W/O OTHER SETTING BOXES
CARPET COVERW/O CARPETMAT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGERETRACTABLE FLOOR STORAGE COMPARTMENT
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
LATERAL BLINDSWITHOUT SIDE BLINDS
TRIM ADAPTATIONHEART OF THE RANGE GEAR LEVER KNOB+PVC GAITER
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLSIMPLE CENTRAL LOCKING
STEERING WHEELLEATHER COATED STEERING WHEEL
Electrical
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
ALTERNATORALTERNATOR 150 AMP
BATTERYBATTERY L2 640 60AH EF 640 EN
STARTER MOTORCLASS 6 STARTER MOTOR
SPECIAL LIGHTINGDAYLIGHT RUNNING LIGHTS
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARMINOR INDEX "02"
CONDENSER (SPECIFICATIONS)CONDENSER 19.2 DM - THICKNESS 12CM
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSSTANDARD SIDE BUMPERS
SET OF KEYS1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATEW/O ADDIT HOMOLOGATION PLATE
Here's the 1.5 Later vehicle, VIN ending 354
AS/RP N°15633 VB 1 3318
Warranty Start Date20/11/2019
Engine serial number10 Q3BF 0496042
OPB00BD
BERe4*2007/46*1241*07
P4A9828808499
General Information
ENGINEDV5RD 75KW 1.5L DIESEL
TRANSMISSIONSTT TYPE 6-SPEED MANUAL GEARBOX
BODY COLOURKVE - SWITCH BLADE GREY PAINT
GEARBOX (CHARACTERISTICS)MB6GW
BADGEFAMILY BADGE
Fuel Supply-Engine
STOP AND STARTWITH STOP AND START STARTER
EMISSIONS STANDARD (ENGINE)EURO 6.2 ENGINE EMISSION CONTROL
CAPACITY1500 CM3
POWER VARIATION (ENGINE)75KW - 250NM
VALVE PER CYLINDER2
DEVICE (ANTIPOLLUTION)EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
GEARBOX TYPEMB6 TYPE GEARBOX
FINAL DRIVE RATIOAXLE RATIO 19 X 75
TYRE (SIZE, TYPE)TYRE 195/60 R16 89H NON REINFORCED
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 4
ABSWITH ABS BRAKES
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
Body Fittings
FINISHER (SELF-ADHESIVE)MATT BLACK REAR SURROUND TRIM
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR+DIODE
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
FRONT PANEL BLANKWITH AIR INTAKE MODULE FR FACE CLOSER
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
Interior Fittings
LUGGAGE COVERSHELF
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
DRIVER’S WINDOW LIFTSEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
HEATING ELEMENTHEATED SEAT
WIFIWITHOUT WIFI
RADIO RECEIVERDIGITAL CONNECTED COLOUR RADIO
REFRIGERATIONAUTOMATIC AIR CONDITIONING
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
OBSTACLE DETECTION SYSTEMREAR RADAR OBSTACLE SENSOR
TRIM ADAPTATIONLEATHER KNOB + PVC GAITER
Electrical
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
BATTERYBATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTORSTTD STARTER
MULTIPLEXINGECO ELECTRICAL ARCHITECTURE
Miscellaneous
almirjaha
Re: VIN Help
