Yes, I know the following is illegal, but I'm just enquiring out of idle curiosity, of course:
Anyone know whether the engine management on the current Citroen 1.5Hdi diesel as fitted to the C5 Aircross etc is locked out to tuners? I believe a few years ago you could switch off troublesome AdBlue systems and eco-optimise this engine to produce cleaner exhaust than standard. Someone told me some makers have now locked the engine managements systems to prevent tuners accessing such things - thanks!
Is the current Citroen 1.5 Hdi engine locked out to tuners?
Maxr
- x 6946
Re: Is the current Citroen 1.5 Hdi engine locked out to tuners?
Can't provide any advice on this forum for that as it is illegal to disable emissions systems as you've said.
But yes more ECUs are protected with anti-tune technology by the manufacturers which in your case will be Bosch. There is no bypass I am aware of at present for these newer ECUs of which yours is likely to be a MD1CS003.
Maxr
