Citroen ZX Volcane TD tensioner pulley assembly
gigaFranc
Unread post by gigaFranc »
Hi
I need a replacement fan belt tensioner puller 'assembly' for my zx Volcane TD, the belt is squealing at the start of journeys but settles down after a few minutes.
I can find the pulley arm, but I need the sliding nut and bolt.
Anyone able to help me out with some knowledge, places to look, ask?
It’s quite hard as I haven’t removed the unit, and I can’t find any diagrams online to help.
Just by way of more explaining, the situation is the bracket is bent and the sliding nut and bolt to make adjustments are seized so all of these need replacing.
This is advice fom the mechanic who is my go-to engineer and also worked on the assembly line.
I know this could equally find an answer in the Peugeot forum, but as it's a Citroen and as I reckoned any knowledge would find it's way here...
Thanks 😊🤞
x 6955
Re: Citroen ZX Volcane TD tensioner pulley assembly
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
gigaFranc
I did get a screenshot from Chevronics that has the pulley but not the nut and bolt...
Adding it to check that you have a more detailed breakdown from the Citroen online catalogue
