Fitting new battery
C5_Jack
Fitting new battery
Unread post by C5_Jack »
Hello All
Quick question, I am about to change the battery on my car 2013 X7 C5.
Do I need to let the system know I have changed the battery?
Or will the basic BSI reset be, ok?
Kind regards
Jack Morgan-Smith
vallium
x 16
Re: Fitting new battery
Unread post by vallium »
Don't think there is any setting for new battery but there is one for its capacity.
C5_Jack
Thank you for the information
Would you know in which menu the battery capacity is?
Jack
x 1940
Unread post by Paul-R »
If the car had the correct (but worn out) battery before and you've fitted the same type then nothing needs to be done apart from observing the disconnection/reconnection procedure,
x 6945
Correct - nothing to change if replacing with same type and capacity. Just follow the BSI Reset / Battery Disconnect / Reconnect Procedure
C5_Jack
Thank you for the confirmation
vallium
x 16
C5_Jack wrote: 01 Aug 2024, 21:16 Thank you for the information
Jack
You need Diagbox for that, probably somewhere under BSI or perhaps battery management
x 6945
It will be under the battery charge status unit, but as said, not required for a simple like for like replacement.
x 1940
You could go in just to confirm that the correct battery is registered.
