Timing belt replacement torques
dylan26__
x 22
Unread post by dylan26__ »
Hi all, just got a new timing belt and water pump kit which I'm gonna tackle this week at some point. Could I possibly get the torque figures for the pulleys / water pump / tensioner please?
I've also bought new engine mounts (both sides) so if anyone knows the torque they need to be done to it would be helpful
2010 Ds3 1.6hdi 110
Many thanks, Dylan
x 6946
Re: Timing belt replacement torques
ReferenceFixingsTightening Procedure
(1)Bolts (Camshaft Pulley )Pre-tighten to 2 daNm
(1)Bolts (Camshaft Pulley )Angular tightening to 50°
(2)Bolts (Camshaft Bearing Caps)Pre-tighten to 0,3 daNm
(2)Bolts (Camshaft Bearing Caps)Tightening to 1 m.daN
(3)Nut (Timing Belt Roller Bearing )Tightening to 3,7 m.daN
(4)Stud (Timing Belt Roller Bearing )Tightening to 0,6 m.daN
(5)Bolts (Shift Prevention Bracket)Tightening to 0,6 m.daN
(6)Bolts (Engine Speed Sensor )Tightening to 0,8 m.daN
(7)Bolts (Timing Belt Tensioner Roller)Tightening to 3 m.daN
(8)Bolts (Lower Timing Cover)Tightening to 0,5 m.daN
(9)Bolts (Upper Timing Cover )Tightening to 0,4 m.daN
(10)Bolts (Camshaft Position Sensor)Tightening to 0,8 m.daN
ReferenceDesignationStageTightening torque
(1)Bolts (Coolant Outlet Housing) (*)Pre-tighten0,3 daNm
(1)Bolts (Coolant Outlet Housing) (*)Tightening0,8 daNm
(2)Bolts (Coolant Pump)(*)Pre-tighten0,5 daNm
(2)Bolts (Coolant Pump) (*)Tightening0,9 daNm
(3)Bolts (Coolant Inlet Manifold)Tightening2 daNm
(4)Bolts (Coolant Pipe)Tightening0,8 daNm
*: Follow the tightening sequence.
Order of tightening of the 4 coolant outlet housing fixing bolts (1)
