there is a engine fault coming up on my dash and its the deisel additive pump ,peugeot want over £400 for a new one,
any suggestions would be appreciated ,foned a car parts firm and they said main dealer supply only .
- x 6950
Re: deisel additive pump
This isn't very clear - you don't usually get a fault concerning the failure of the diesel additive pump! It is usually a warning telling you the diesel additive level is low or needs topping up.
Can you confirm what the exact message you have on the dash is. If it just needs topping up you don't need a new pump.
platerbaker
the warning on the dash says engine fault ,put it on a diagnostics and that came up as the deisel additive pump ,already had a new additive top up fitted ,cheers .
- x 6950
And you also reset the additive counter after you topped it up?
What is the specific code reported by your diagnostic tool and your VIN? Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
