Wont charge - 2013 Berlingo
Olekristian123
Unread post by Olekristian123 »
Hi, I have a 2013 Citroen Berlingo. I'm having trouble with charging; the alternator isn't the issue. I'm attaching a video where I demonstrate the problem. When I unplug a connector, it starts charging, but the connector must be plugged in for the car to start. However, it won't charge when the connector is plugged in. Any help is appreciated.
P.S.: I have replaced the fuse box in the engine compartment with an identical one.
x 1484
Re: Wont charge
Your video is not attached? If you upload to youtube then put the web address in here it will appear automatically.
x 1930
Re: Wont charge
Unread post by Paul-R »
How sure are you that the replacement fuse box is the same? Are the numbers on the boxes the same? The boxes can be similar and that isn't good enough.
x 1484
Re: Wont charge - 2013 Berlingo
I've moved this into Citroen forum, and re-named for clarity.
x 1438
Unread post by xantia_v6 »
Have you tried fitting a new battery?
I have had failure to charge with an old but still functioning battery due to the alternator mistakenly believing it to be fully charged.
