Hi, I have a 2013 Citroen Berlingo. I'm having trouble with charging; the alternator isn't the issue. I'm attaching a video where I demonstrate the problem. When I unplug a connector, it starts charging, but the connector must be plugged in for the car to start. However, it won't charge when the connector is plugged in. Any help is appreciated.
P.S.: I have replaced the fuse box in the engine compartment with an identical one.
Wont charge - 2013 Berlingo
- x 1496
Re: Wont charge
Your video is not attached? If you upload to youtube then put the web address in here it will appear automatically.
- x 1943
Re: Wont charge
How sure are you that the replacement fuse box is the same? Are the numbers on the boxes the same? The boxes can be similar and that isn't good enough.
- x 1496
Re: Wont charge - 2013 Berlingo
I've moved this into Citroen forum, and re-named for clarity.
- x 1473
Have you tried fitting a new battery?
I have had failure to charge with an old but still functioning battery due to the alternator mistakenly believing it to be fully charged.
