Having fitted genuine module and wiring looms, aux as well, can someone point me to a guide using Lexia to update BSI so that stabilisation program works not forgetting also turns rear parking sensors off
many thanks Norman
Citroen Towbar module and Lexia
- x 6946
Re: Citroen Towbar module and Lexia
There's nothing I have on this as it's usually a dealer job to configure the BSI. It involves configuration in several places dependent on what you have fitted, so can't help on this one Norman.
Majanor
Thanks Marc
I'll pursue Dealer option, wouldn't want to be messing around in uncharted waters.
Thanks Norman
Thanks Norman
- x 1941
I fitted a towbar with to my 2013 X7 a few years ago. I bought the dedicated Peugeot looms and ECU and then activated it using my Diagbox. It wasn't difficult. No need for a dealer if you have a suitable full chip Diagbox.
Majanor
Thanks Paul-R, Appreciate the info on Diagbox, I believe the one I have will do the job.
Many thanks
Many thanks
- x 6946
If you can provide me with the part number of the electrical harness you bought, I can perhaps look it up and on some, there are detailed instructions on how to use Diagbox to configure this. Worth a check... pop your VIN up too, Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
